Question about Sharp R-930AK Convection/Microwave Oven
Sharp R930AK The turntable motor broke for the second time in 2 years. The first time it was fixed because it was inder warrenty but now they said too bad. My husbadn is very handi with appliances etc but is hesitant about a microwave. If he gets the part does he have to open the microwave or break the sealwhere the radiation can leak out. Thanks, Edna
  • victor9000 Dec 11, 2007
    There is an access plate on the bottom of the oven which covers the motor. It comes off easily and the oven cover can remain in place.
  • billrideon10 May 27, 2008
    The coupler is melted at the motor, can I get the parts?
  • Sharp Master
  • 9,156 Answers
We have the complete service manual on our site: http://www.microwavedisplay.com/r930ak_aw_sm.pdf It contains all the safety, disassembly and part information you should need. You can order a new turntable motor (and likely a new "motor packing" grommet, and perhaps a new coupler) at Tritronics at http://www.wehaveparts.com
Posted on Apr 24, 2007
The solution was good and the site for the diagrams was very useful but my question about the leakage of the radiation if it is opened wasn't answered.
Posted on May 01, 2007
The TT motor coupling has melted at the shaft. You can be sure of this if the TT tray free spins without any resistance. You will simply need to replace the hard plastic coupling.
Posted on Apr 28, 2007
My over the stove Sharp Carousel Model # R-1505F turn table stopped turning. What part do I need to replace. Also, I broke the glass turn table plate. What size is that and where can I order another...
Sears Parts Direct has the parts diagrams and many parts for the R-1505 microwave. The glass plate is part 4-3 ($33.99) on this page: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R1505/0958/0123370/50019999/00001?blt=06&prst=&shdMod= .
Without more tests, I can't be completely positive but the turntable motor is the likely problem. That is part 1-4 on the list above. However, it could be a wiring problem with the wiring to the turntable motor.
Partstore.com has many of the parts as well: http://www.partstore.com/Model/Sharp/Sharp/R1505.aspx .
I hope this helps.
Jul 29, 2011 | Sharp R-1505 Microwave Oven
My Sharp R957 turntable seems to be sticking. I've cleaned under the turntable and the support but it doesn't seem better. If I give it a push it works for a bit then slows down again.
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 16, 2011 | Sharp Microwave Ovens
Sharp microwave (R-959m) turntable not moving
Sounds like a new turntable motor is required.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Dec 28, 2010 | Sharp R-930AK Convection/Microwave Oven
Microwave turns on but doesn't heat. Turntable does not rotate
The magnetron (the part that heats the food) is probably done, they tend to go out if the fuse didn't blow and it usually isn't worth fixing as the cost of the magnetron is almost what it would cost to buy a new microwave.
Sorry for the bad news.
Benjamin
Mar 25, 2010 | Sharp R-930AK Convection/Microwave Oven
Sharp R963 microwave turntable stopped rotating. I suspect the motor broke. How could I replace this please? It seems there are no ways to open the bottom of the oven. Thanks
You have to remove the cover to see how to do it ...
I had a similar trouble several years ago with my Sharp. I dont recall the specific details but I do recall it was easy after I got the cover off and studied it a little bit.
Turned out it was not the motor in my case ...
Oct 26, 2009 | Microwave Ovens
Has anyone replaced the Turntable Coupling?
You will need to remove the motor to get it off.
We have the full R-930AK/AW service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it.
Here's the procedure:
1. Disconnect the oven from power supply. Remove the turntable tray, and the turntable support out
of the oven cavity.
2. Turn the oven upside down and remove one (1) screw holding the turntable motor cover to the base plate and take off the turntable motor cover.
3. Disconnect wire lead from the turntable motor.
4. Remove the two (2) screws holding the turntable motor and coupling mounting plate to the oven cavity bottom.
5. Turntable motor, Coupling mounting plate and Thermal protection plate bottom will be free.
Sep 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Microwave, convection R930AK turntable will not turn and microwave will not cook. inside light works
That would be a defective secondary (lower) door switch or possibly the door switch mount is loose or misaligned.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Adobe Reader to view or print it.
The best place to order Sharp parts is Tritronics.
Aug 29, 2008 | Sharp Microwave Ovens
Sharp Carousel Model R-9H56
Check that the plastic connector from your motor to the turn table is not broken , mine broke and it took weeks to solve the problem. Try rotating the part that protrude into the oven. If you can turn it by hand it is broken, lucky cheap to replace
Nov 21, 2007 | Sharp R-510HW Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
332 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
