Kv8 pro POSTcode 25
Kv8 pro POST CODE 25 ...tried replacing ribbon cable, key borad, and resetting CMOS comp startup is still stopping at POST code 25 any other suggestions?? (boyfriend is pulling his hair out)
  • dreamweav135 Dec 29, 2008
    well, mederbil, the comp we were working on USED to be a sony vaio, but has since been upgraded with the abit kv8 pro motherboard, geforce fx 7200 from a geforce fx 5200 graphics card, and up'd the ram to dual 512 mb sticks for 1GB RAM all were compatible. as a last resort he swapped the 7200 graphics card back to the 5200 card before taking it to the shop, and voila the darn thing works again. we'll be taking the newer card back of course lol. thanks to all who responded to me...it was very quick that i got a response and very helpful. thank you soooo much!!
  • mederbil May 11, 2010
    What model of computer are you using?
    Champion:
  • 253 Answers
Check your graphic-card.is the graphic-card supportet with your motherboard?
pci-agp.... take it out and try the onboard graphic-card.
Or try with 1 ram block...
Posted on Jan 16, 2009
  • markus
    markus Jan 16, 2009
    check your graphic-card.is the graphic-card supportet with your motherboard?
How do I set a journey with just the postcode
Problem . Several towns or places can have the same postcode. you wont have much luck if place name is not known. Google-- name places with postcode zxzxzx in mnkjgh. zxzxzx your post code ,mnkjgh your country. if you luck is in and only one place name comes up. bring up Google maps , type in place name and post code . then your address a postcode . using from to mode. Google will draw you a map.
Sep 17, 2014 | Garmin Nuvi 50 LM
What does code 7f mean on kv8 pro
Did you ever resolve?
This is the board with the external OC monitoring panel, right?! I owned this, too. I had a similar KV8 board from Soltek, as well--post codes, also. My Abit died several years ago.
The ABit's manual still exists online. According to the code, It's hanging on the onscreen logo--it says to switch to text. Here's the page describing your code: http://www.manualslib.com/manual/615/Abit-Amd-Athlon-Kv8-Pro.html?page=69#manual
If I remember correctly, that's not a serious error code--popped up often after new installs.
If it's a hard drive error--do you have the master/slave configuration jumpers correct? (Hard drive vs. Optical drive? Probably, you want the hard drive as master--optical as slave)
Is cable orientation (Pin 1--from PATA cable and at drive(s)/board) correct? Perhaps I remember now--maybe the BIOS can't get to the hard drive and OS.
Is your floppy light always illuminated (it shouldn't be)--is that cable installed correctly?
If your onboard hdd controller is dead--and, you worked with AGP over the years--you likely have a PCI card that will take its place. (If not, you may purchase that pretty easily. still.) Syba, Siig, Sabrent, StarTech, etc.
If your controller is OK, have you tried running a live i386 (32-bit) or AMD 64(64-bit) Linux disk or an old Bios upgrade/DOS floppy--to see if you get some type of OS posts? Is your proc 64-bit or 32-bit?: If I remember correctly, 754 CPUs generally were 64-bit--some were 32-bit, though (I still own one of those, too).
Did you clear your CMOS first (move the jumper for a few seconds and back)? Is the jumper correctly installed now?
Ah, the days of socket 754 (I never obtained Socket 939.....) Socket 754 still is a good value--you may obtain such a proc for about $5 on Ebay. (Used boards are a little pricey--considering.) I get the sense that 754 was the business board--939 was the gamer board.
Recently, I resurrected my old Shuttle Athlon XP board--considering its age, it holds up pretty well. Works fine with 32-bit Linux Debian distros. Dual-channel. Great OC board in its day. Currently, I have a 9800XL card in--soon, I'll put in a 3850 AGP....
May 23, 2014 | Abit KV8 Pro Motherboard
Tomtom troubleshooter
Search tomtom website and download the latest postcode file (it ends .zip) and using windows copy this file to your device and it should work using post codes again. Ensure the file retains the .zip extension as it is not a zip file as one would know a zip file in normal computing to be a compressed file but .zip for the american name for a postcode being a zip code. I cannot remember if this file is copied to the main part of the tomtom or the map so try main part first.
Sep 04, 2013 | Tomtom One XL GPS Receiver
Problem with my sapphire x1650 bootup
Whenever you install, add or remove hardwares from your computer, always clear the CMOS or reset the BIOS Settings. Try these methods:
http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm
Mar 01, 2010 | ATI RADEON X1650 Xt, (256 MB) Graphic...
Brother SX 4000 stopped printing. Ribbon is
Remove and inspect the ribbon cartrige, wind the knob and make sure that the ribbon moves and reinstall. Check that the correction tape is installed properly. Check that the ribbon plate assembly is not in the correction position. Try CODE RESET (Q key)
Dec 22, 2009 | Brother Office Equipment & Supplies
Oven is beeping flashes f7. goes from push start for hi broil to low broil
HI, your key pad or touch pad is malfunctioning. most units will have a integrated touch pad. In this case, you will need to replace the entire control board, in order to restore normal functions. Now, if you units control and key pad are separate entity's, i recommend this test below to determine which is at fault.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 21, 2009 | GE Ovens
How do i reset CMOS on kv8 pro? getting POST code 25 comp not booting up, tried replacing ribbon cable, also unplgged keyboard. HELP!!!
unplug your computer, then you will find a small battery on the motherboard, this is a small silver disk shape. you need to remove this by pressing the clip to its side, this lets it spring free. you then need to locate the cmos jumper. this is a 3 pin stand off with 2 pins already covered by a plastic sleeve. remove the sleeve and place it over the other two pins, wait a few seccons then put everythinbg back to the way it was. put the jumper back in its origional position and re-attach the battery making sure it is the right way up. plug in your system and give it a try.
Dec 28, 2008 | Computers & Internet
Start up problem
Try to use another keayboard, if that dosent work, try to do a full >CMOS reset.
error 25 is a weird 1 as although it's supposed to relate to gfx it's also been seen to be apparently associated with faulty IDE cables/drives & even keyboards
Good luck to you
Dec 27, 2008 | Abit KV8 Pro Motherboard
Computers & Internet Logo
183 people viewed this question
David Payne
David Payne
