Question about Nintendo Guitar Hero Wireless Guitar - Wii for Wii
This may sound silly but where do you plug both of the cymbals in
We just got ours and set it up today. My son had same problem. The holes to plug in the cymbals are right underneath the cymbal pads, on the side of the bar holding up the pads. If you study the directions carefully, you can see where they are directing you to plug them in.
Posted on Dec 28, 2008
I have a td11 it has an extra output to add a third cymbal.Can that cymbal output be split to get an extra cymbal
Info I have found suggests that the Crash trigger inputs are "piezo/switch" as required for cymbal pads using
Nov 22, 2016 | Music
WHEN I STRIKE THE BASS DRUM, THE CRASH CYMBAL SOUNDS AT THE SAME TIME....EVEN WHEN NO CYMBAL IS CONNECTED TO THE INPUT JACK.
If you leave an input open they MAY cross couple... try plugging a set of headphones into the cymbal input jack... this will ground the cymbal input... then see if you still get the cymbal sound... IF you STILL get the sound, then the multiplexor that scans the input has a problem and you need to take it for repair. Repair on the surface mount boards is not a DIY without proper tools and skills. If the grounding stops the cross coupling, then you MAY have a problem with the cymbal or its cable.
Feb 15, 2011 | Yamaha Dtxpress Iv Special Electronic Drum...
Well the Roland td-4s is a superb kit. I've only had it for a few weeks now and the only issue im having is with the ride cymbal. It is a CY-8 cymbal that came with the set and it is dual triggered, but...
It sounds like the sensor is bad in the unit... If you have only had it a few weeks, exercise your warraaanty for replacement. Repairing the piezo sensor is NOT really a DIY project.
Dec 18, 2010 | Roland A: TD-4 Electronic Drum Set Pads,...
Need to hook up cymbals for Guitar Hero World Tour
Turn over each cymbal. They are marked L for Left (Yellow) and R for Right (Orange) Each cymbal has a mini phone jack located along one side of the base that the mini phone plug that comes out of the adjustable cymbal support column needs to be plugged into. The jack on the back of the console, above the one marked PEDAL, is NOT for the cymbal.
Sep 04, 2009 | Nintendo Activision Guitar Hero World Tour...
One of my cymbals just stop working, i've unplugged it from the cymbal, turned the amp off and on, restarted the system and nothing seems to be working. I did unplug it from the "brain" i believe, (i just...
Try these:
- change the interconnection cable between the cymbal and the "brain" unit, if the problem goes away, you have a bad cable.
- if the problem persists, see if that particular cymbal works well on another input of the "brain" unit, if it does, you have a problem with the input on the "brain unit", this will require servicing if the unit still has a warranty, otherwise you should first check the solder contacts on the input that doesn't work (also check for dirt /oxydation on the plug contacts and clean if necessary).
- If that particular cymbal won't work when you plug it into any "brain" cymbal inputs (it's basically a piezo trigger so it should work on other inputs), then you have either a broken wire on the piezo trigger or on the cable connector in that cymbal (it should be possible to resolder), or the piezo trigger itself is faulty and needs to be replaced.
I hope you can find out what troubles your drum kit.
regards
3rq8 (triarcuate)
Jul 30, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
WIRE IS DISCONNECTED ON DURM SET FOR GUITAR HERO YELLOW CYMBAL
TURN CYMBAL UPSIDE DOWN. IN THE MIDDLE YOU WILL SEE A RAISED RUBBER STRIP. THERE WILL BE A SLOT FOR WIRE TO PLUG INTO CYMBAL
Jul 11, 2009 | Video Game Consoles & Games
Where do the cymbals plug in?
You connect the pedal to the pink hole, then the cymbals goes to the rest that ain't the headset input.
try it out
May 04, 2009 | Activision Guitar Hero III: Legends of...
Can't get left cymbal to work
LOOK UNDERNEITH CYMBAL .THERE IS ABOUT A ONE INCH STRIP.. WIRE PLUGS INTO ONE SIDE OF THAT STRIP
Mar 15, 2009 | Nintendo Activsion Guitar Hero® World Tour...
Cant figure out where to plug cymbales in on GH world tour wii
2 kick plates one for base one for a cymbal ? or mabye 2 plugs one for each cymbal ?
Dec 26, 2008 | Nintendo Guitar Hero Wireless Guitar - Wii...
Nintendo Guitar Hero Wireless Guitar - Wii for Wii Logo
85 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
