Question about Casio Parts Cash Register PC Desktop
I have the cash register Casio PCR265P
When I turned the cash register on the E94 displays on the screen and there is nothing in the printing part that is jammed. Can you help me find the problem and solve it please Email me at hoefler@cableone.net
  • hoefler Dec 29, 2008
    Thank you for trying to help me solve the prblem but that did not fix it. It had been stored for 8 years. It must have had other problems. Thanks MIchele
  • 737 Answers
Hi. Standard problem with this kind of printer. The rotary switch gets dirty. If you want to try fixing it yourself, unplug the machine, remove the screw inside the printer compartment that holds the machine to the drawer. Slide the whole top section forward on the drawer, then lift upwards to remove the cash register from the drawer. Gently turn it over so you can see the bottom side of the printer. On the printer, you will see a black plastic housing at one end with little wires going into it. This is the switch housing. Get a can of general purpose luricant (such as WD40) and spray into the black housing. Try to get the spray into any little gap in the housing, or under a corner. I don't recommend unclipping the housing as it can be difficult to reassemble. Just get the spray generally inside it as much as you can. Don't be afraid to get the spray on other areas, it won't harm it. Your paper might be wet for a few prints that's all.
Once you have sprayed it, plug the machine in and try it. Sometmes it takes a few sprays and on off cycles before it works, but it will usually do the trick if there is nothing else jamming the printer.
Mark
Posted on Dec 28, 2008
  • flexion1
    flexion1 Dec 29, 2008
    Storing for long periods can absolutely cause the rotary switch to give problems. It is probably very badly tarnished and may need to go to a repair centre.
PCR265P CASIO CASH REGISTER ERROR CODE E 94
You have a printer fault. Check to see if it is jammed.
If anyone is having trouble programming a Casio PCR265P, the manual is here:http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-265P_users_manual.html
Dec 11, 2012 | Casio Parts Cash Register PC Desktop
I have a PCR-265P and an E94 error
You have printer failure. Check for any paper jams in the printer. Otherwise, the printer may need replacing.
If anyone needs a manual for a Casio PCR265p, try here:
Jul 07, 2012 | Casio Parts Cash Register PC Desktop
Sir good evening i have cash regester casio 160cr.Error code is e94 pls help how i can run my cash regester thanks.
I suggest you to reset your equipment.Here is how:
Remove AA batteries and unplug register from wall for 15 minutes.
Two more options;
Option #1:
To print the transaction details before clearing the journal memory:
VERY IMPORTANT: Do not interrupt once printing begins or the journal will not be cleared.
1. Make sure the paper is full in the register.
2. Turn to Z mode.
3. Hit the RC key until the screen displays "E94".
4. Hit Cash Amount Tender.
Once the printing is completed, the journal is cleared and the register is ready for use.
Option #2:
To clear the journal memory WITHOUT printing the transaction details:
1. Turn to Z mode
2. Hit RC key until the screen displays "E94 Clear"
3. Hit Cash Amount Tender
Nov 27, 2010 | Casio Parts Cash Register PC Desktop
We have an error showing - E94 and we cannot get any keys to ring or open the cash drawer. How can I fix this?
This sounds like a Casio. E94 refers to printer failure. Check to make sure their is nothing jamming the printer. Remove the paper/ ink cartridge etc, then turn off at wall. Turn key to REG. Turn on at wall
Casio cash register operating / user / programming manuals here: http://the-checkout-tech.com/cashregisters.php
Aug 04, 2010 | Casio Parts Cash Register PC Desktop
On the screen there is a E94 error messagage on the Casio P260 cash register . How can I correct this error and reopen the cash register.
E94 is a printer error. Open the printer and make sure nothing is jammed in it.Remove the paper roll. Look for old pieces of paper stuck in the gears etc. ----------------------------------------------------------------------------------------------
If anyone needs a Casio PCR-260 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
Jun 16, 2010 | Casio Parts Cash Register PC Desktop
E94 code
I personally don't know. But try this. Go to the casio site probably www.casio.com, and try to download a manual, or google casio(use model number)+manual . no spaces in the search. Most times I have had good luck with this method. It works with older faxes, phones,etc. good luck
Jun 17, 2009 | Casio Parts Cash Register PC Desktop
Cash register showing E94
Hi. It has a printer fault. Make sure there is nothing stuck in it. If the printer spins at turn on then it is probably an electrical problem and you need to take it to a dealer.
May 02, 2009 | Casio Parts Cash Register PC Desktop
Casio PCR265P error E94
CASIO support like please try 800-633-5586 or 973-361-5400 ext 4434
Nov 13, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
115 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
