Question about Disney Mix Max Digital Media Player
Dvd to memory card for mix max
How do I get dvd's onto a memory card. I'm using dvd ripper and that puts it onto the mix max, but I want it on a memory card.
  • 1hart Jan 22, 2009
    how do you set up the profile?
  • nboerner May 18, 2009
    get movies onto mix max but cant play form sd card
Go get the windows media encoder its free. Set the profile that comes with it up . I get 8 to 10 full length movies on a sd card.
Posted on Jan 12, 2009
I just bought one for my daughter, I can get Videos to work , from the Sync , window media player 10 software , but any time i try to stick in a Sd card , Even a NEW one. It just continuously flashs DO...
Your sd card is to big go down to a 2gb card on the 512mb mix max. Only the mix max plus will support 4gb cards. Also I could never get windows to support files so i used pocket dvd wizard to convert it is 15 bucks well spent and you can convert with the card in the device and save it to windows media to drag and drop in the future.
Nov 13, 2010 | Disney Mix Max Digital Media Player
How do I load a dvd onto my walkman.
First off get the arcsoft media converter 3, then drag and drop the videos you want to get on your mp3 player into the program, after it converts it loads them onto your mp3 player as long as it?s connected, this program will also allow you to download YouTube videos and put them on your mp3 player too.
Oct 26, 2009 | Sony Walkman NWZ-S616F MP3 Player
How do i put dvd's onto the archos from my pc
Hehe. get a program like dvd decrypter and ripa DVD then use Handbrake or something to encode it in Xvid. This is the free/long way to do it.
Jul 07, 2008 | Archos 604 Digital Media Player
How do you put movies dvds and videos on your mix max mp3 player?
I think I've covered this one before... not sure though so here we go...
First of all DVD's are copyrighted and digitally encoded so that they can't be copied to your computer or other devices. Windows Media Player can't rip them because of this encoding. Not only that if you were somehow able to copy it to the player the Mix Max can't play DVD formatted videos, it can only play WMV (Windows Media Video) formatted videos that are properly "encoded" for play on the Mix Max.
Check out the link below for how to properly encode your videos for play on the Mix Max.
http://digiblue.com/customer-service/faqs/disney/mixmax/index.html
It has a PDF download with instructions on how to properly encode videos so that they will play on the Mix Max.
May 08, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max problems
The memory could be corrpt in the player. It some times happens so try reformatting the memory to clear it up. This will erase everything and then you can put your songs and stuff back on it. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Mar 21, 2008 | Disney Mix Max Digital Media Player
Ok these are the directions from start to finish.
You need Prism Video Converter and Windows Media Encoder 9 series. You can google both and download for free. You use Prism Video Converter to convert AVI or whatever file to WMV and then use Windows Media Encoder 9 Series to convert the WMV file to a WMV9 file. I know its stupid but if you follow my directions it will work and it cheaper then buying the individual cartridges. Once you have these installed do the following.
Click and open up Prism Video Convertor.
Click to "ADD FILES" on top toolbar. Find and choose the movie you want to convert and double click on the movie and it will add it to the list. Add all the movies that you want to convert. Each one takes about an hour.
At the bottom choose a different output folder. Then scroll through the OUTPUT FORMAT tab at the bottom and choose. .WMV
Click on ENCODER OPTIONS and change everything to the following:
Video Compressor------ Windows Media Video 9
Video bit rate ------------- 4096
Sound Compressor ----- Windows Media Audio 9.2
Sound Format ------------ 128 kbps,48 kHz Stereo CBR
Press ok and then click on VIDEO OUTPUT OPTIONS and change everything to the following
Make sure that there is a check next to RESIZE VIDEO "Shrink or enlarge video to selected size."
Width---- 220
Height --- 176
Make sure that there is a check next to CHANGE FRAMERATE
30.00
Click on OK and then CONVERT when the movie is finished you can move on to the next step
STEP 2
Open Windows Media Encoder 9
click on COVERT A FILE and press OK
Then choose your source file ( the movie you just converted with Prism)
Then Choose a new output file like make a new folder and name it MIX MAX MOVIES and click ok
On the next screen just press ok. Don't worry about the setting at this point because we will change them later.
Name the movie. and click ok and FINISH
Once the converter starts press the STOP button on the top toolbar., its RED, a window will pop up, click CLOSE to close the window. Then at the top of the converter click on the PROPERTIES tab. A window will pop open. Click on the COMPRESSION tab in the middle of several tabs. Click EDIT on the right hand side of the COMPRESSION window.
Now you should see 2 tabs. A GENERAL tab and a 259kbps tab
On the GENERAL TAB change everything to the following:
Make sure Video and Audio are both checked
Audio CBR Windows Media Audio 9.2
Video CBR Windows Media Video 9
Click the 259kbps tab and change to the following. ( If you see something I don't mention here THEN DON'T CHANGE IT )
Audio Format 128 kbps, 48 (NOT 44) kHz Stereo CBR
Video Size 220X176
Frame Rate 30
Key Frame Interval 2 sec
Video Bit Rate 384K (this is a little tricky. MAKE SURE IT SAYS 384K)
Buffer Size 5 sec
Video Smoothness 0
Decoder Complexity Simple
for a total of 521.02
CLICK APPLY and wait a few seconds for it to apply and then START ENCODING on top toolbar. When this movie is finished it will play on your MIX MAX, if it still says that the FILE IS NOT SUPPORTED then you have to go into the setting on the max and change the mass storage setting. There are 2 choices can't remember off hand what they are but choose the opposite one obviously and try again. Also you actually have to go to the movies or video tab on the max player not NOW PLAYING cuz that button is pointless.
any problems email me @ cera1756@gmail.com
I have converted many movies that have worked on both our players so if you follow these directions correctly there shouldn't be a problem.
ENJOY
Jan 18, 2008 | Disney Mix Max Digital Media Player
Downloading videos onto Mix Max
Yes, you can download "any" video you want to the mix max, but to do it from a DVD, you will have to first get the video from a DVD and convert it to a mpg file, then follow the instructions here.....
http://disney.memorexelectronics.com/downloads/DMP9050_WMV_encoding.pdf
Jan 08, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
204 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
