Question about GE 35GT690 35" TV
GE 35GT690 (No remote, how do I set it to Video?)
I own a GE 35GT690 TV, its probably from the late 90s or early 2000, I bought it from a friend with no remote control, I recently got FIOS and the technician was somehow able to set my TV to Video, so that the cable could work; however I accidently changed the channel on the TV and can not get the TV to go back to Video (Channel 3-4 wont work). I called Verizon and they said they could send somebody out, but would charge $100 to come out!! Can anyone help me out here?? Once again I just need my TV to switch to Video without a remote. Thanks for your help!
    Genius:
  • 1,074 Answers
Probably you could try this push down the channel up and down button together.you menu will pop up then you can change your setting with the volume up and down button good luck.any further assistance contact me at email nicodhem@yahoo.com or on the fixya.com expert website.
Posted on Apr 24, 2007
When was this TV manufactured?
looks like an early 90s model # the date of manufacture should be on model # label
sorry the manual for this model was printed in 2000
so must be a 2000 model
Dec 22, 2016 | RCA Televison & Video
Cub Cadet garden tractor. Where can I get a manual covering clutch replacement?
probably just needs a new drive belt . they do stretch a lot
Mar 05, 2016 | Garden
My 625 unit (often not always) stops early and I miss the last min or so of the show. I have set all timers to 0 early and 0 late.
Hey jimmie love,
Just a quick clarification; does this only happen on certain shows? Some channels do run late.
You can always try setting the timer to end 2-3 minutes late and see if that works. Let me know here if you have any information or if you have any questions.
Tommy Faust
DISH Internet Response Team
Dec 12, 2011 | DISH Network DVR-625 DTV Receiver /...
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
My cr80 honda will not start.It as been diagnosed with an ignition problem.However we do not know wether it is the stator plate, flywheel or pick up.Is there any way to tell? Please note the bike is a CR80...
try to kick it over very slowly....my friend had one and he kicked it really fast for years with this kind of problem...one day he got tired of this and just tried it real slow and methodically and it started. i hope this helps.
Sep 15, 2009 | 2004 Honda CRF 100 F
I know of two Bonnevilles that leak into the back seat and floor when it rains. Is this a common problem with this late 90s cars
Yes and No, depending if the car has been sitting out in the sun longer than others. over times seal tend to wear or rotten especially the one setting out more in the sun. back window tend to get beaten more its the way the window sit exposing more to the sun, beside the front windshield which has stronger and thicker rubber. Manufacture who produce those rubber seals for GM, I never though they were good seal. GM always has problems with there rubber seals when it come to convertible and T- tops. back in the the early 80's to the late 90's was horrible. 2000' are much improvement.
Jul 10, 2009 | 1996 Pontiac Bonneville SE CA Value
Broken rear axle brackets
Find a local engineer who uses wax impregnated nylon, it can be machined to your requirements just like billet steel and will last much longer than the original.
Mar 14, 2009 | Cars & Co Collectible Pedal Cars
Will not show channels below 51
The GE (actually RCA) 35GT690 uses the CTC187 series chassis. The tuner uses the VHF circuits for cable channels lower then 51 and the UHF circuits for the higher channels. This means that the VHF circuits have stopped working in your set. I usually find that this is caused by a defective U7301 IC in the tuner, the SIP IC labeled CXA1594L. This is a very difficult IC to change and all tuner ground solder joints should be resoldered too, so that should be done by someone with experience in the CTC187 chassis.
Jul 05, 2007 | GE 35GT690 35" TV
Televison & Video Logo
973 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
