Question about Samsung SyncMaster 2253BW LCD Monitor
Samsung syncmaster 2253BW blurry/out of focus HELP!
Just bought the Samsung Syncmaster 2253BW monitor and I am not sure about the settings, the picture is alright but it looks like it is a bit blurry and a bit out of focus, I used the cables that came with the monitor, does that make any difference? If so what should I buy or do I just need to adjust the settings....the monitor is hooked up to a macbook...Thanks!
  • Anonymous May 18, 2009
    "Samsung syncmaster 2253BW blurry/out of focus HELP!" problem, and notify you when a new solution is offered.
  • 4 Answers
Cables wont make a difference, are you sure your display settings are set to 1680 x 1050? i have had problems when it is set to 1600 x 1000 and i had to reinstall the video card drivers.
Posted on Jan 09, 2009
My Samsung crt monitor syncmaster 794mg is blurry I use as tv for month and and reconnect with system the monitor became blurry pls help
blurr y means focus out.
Also adjust brightness (reduce and check half an hour if not blur quickly need to adjust focus)
therefore need to getting help by professional technician to adjust the focus preset in the Fly back.
Also need to careful to avoid arc high tension voltage from anode and from fly back.
Also don't turn white balance much . may be monitor display off when power on if turned more. if reduce much monitor will black.
Jan 25, 2016 | Samsung Computers & Internet
Everything is blurry because the settings were played with...can i have the original factory settings like :brightness %...etc??
the blurry is caused by the FBT voltage open the cover and correct the focus Horizontal and Vertical with the scewdrive
Sep 29, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
How to change aspect ratio?
change it by right clicking on the desktop and then selecting, in vista, personalize>display settings, or in xp, properties>screen resolution
Aug 06, 2010 | Samsung SyncMaster 2253BW LCD Monitor
Samsung 2253bw lcd monitor makes loud, fast ticking noise > 10hz. Noise occurs even when monitor is powered off with switch.
Turned out ticking noise was harmonic vibration triggered by a nearby airconditioning compressor. Once I guessed the cause, putting a rubber pad under the monitor to dampen the vibrations eliminated the ticking. Removing the pad caused the ticking to reoccur. Ditto with turning the A/C off or on. Weird!
Jun 05, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Fuzzy/blury fonts on a samsung syncmaster 920nm
Good morning! Please review/check the set-up settings of your samsung flatscreen, best to refer it to the operations manual of the monitor which should be included when you bought it. best regards.
May 02, 2009 | Samsung SyncMaster 920NW Monitor
SyncMaster 2253BW LCD Monitor doesn't fill screen in game's
you can change the size of the screen by going to the set up screen (menu) then adjusting the third box down the coarse and fine and the verticle and horizontal positions my settings are course 1798 fine 48 h position 56 v positiion 50 hope this helps regards Jim
Feb 14, 2009 | Samsung SyncMaster 2253BW LCD Monitor
SyncMaster 2253 BW Samsung
Hi...there,
Have try open your monitor on screen display (OSD) and used the auto adjust settings.
Oct 13, 2008 | Samsung SyncMaster 2253BW LCD Monitor
Samsung SyncMaster 2253BW LCD Monitor Logo
657 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
