After installing a kenwood cd mp-208 in my daughters car, she now informs me that she has no dash lights. Not sure if i have everything hooked up right or not. Any help would be appreciated.
During the install there may have been shorted out check the fuse panel inside the car, this may be in the glove box or behind one of the front panels on either the driver or passenger side.
Posted on Dec 28, 2008
Starting up a kenwood KDC MP 149 car stereo
Try checking all of your fuses. You should have two fuse boxes, one in the engine compartment and another under the dash or in a kick panel inside of the car. There is probably a fuse on the back of the radio also.
Jul 19, 2012 | Kenwood Car Audio & Video
Kenwood KDC-319 CD Player Logo Problem with KDC-319 CD Player installed a kenwood kdc 319 in a 04 chevy malibu when i have car off i turn deck on an my cars dash board lights turn on Posted by A
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Jun 25, 2012 | Kenwood KDC-319 CD Player
I installed radio everything works except no sound from aftermarket speakers. Radio was hooked up in another car everything worked fine!
Double check your speaker connections. Make sure + goes to plus and - to minus (phase) and make sure all are grounded properly. Is there an amp possibly in line? If so, make sure connections are good there also make sure powered up (it happens to all of us)
Feb 26, 2011 | Kenwood KDC-MP228 CD Player
Wiring problems?
http://inform3.kenwoodusa.com/manuals/kdcmp238.pdf
There are no illumination wires on this deck, so the Orange and orange/wht are not used on the wiring harness. Orange wire is NOT for memory. Yellow wire is +12VDC Constant for memory.
If you hooked up the 12Vdc to the orange wire, your fuse for your dashlights have blown. Check your cars fuse panel for a blown fuse.
The orange wires are sending a signal out to radios with illumination circuts. You just sent a 12VDC signal upstream and it collided with the Cars signal and blew the fuse.
Tape off the orange wires, and all will be fine after changing the fuse.
Dec 28, 2008 | Kenwood KDC-MP208 Car CD/ MP3 Player
Blaupunkt kingston MP 47, unable to fine tune even frequencies
PRESS 3 AND 6 TOGETHER  and switch on the set and select the country .for example USA EUROPE and THAI for asia and press ok/menu button  .Pls try this.
R Murali (mailbox.murali@gmail.com)
Dec 06, 2008 | Blaupunkt Kingston MP47 CD Player
Kenwood stereo Won't turn on
look and see if there is a reset... usually a tiny hole you can push a pen point into...(lightly)
Jan 27, 2008 | Kenwood KDC-MP205 CD Player
Toc code keeps comeing up on my kenwood kdc x5589
Hi, toc error means that the laser is struggling to read the Table of Contents which tells the unit where all the information is on the disc, it may be something as simple as the lens needs cleaning or something as complicated as the laser needs replacing, but you could try running a cd disc cleaner through it first. Good luck......
Jan 24, 2008 | Kenwood eXcelon KDC-X559 CD Player
20 people viewed this question
 Grubhead
Grubhead
