NOTE: Because each of these steps represents a possible solution to this issue, check the A/V receiver status after completing each step.
IMPORTANT: If the A/V receiver is used at maximum volume level, it may enter the PROTECT mode. Maximum volume listening will cause the A/V receiver to run very hot and may drain the output capacitors.
IMPORTANT: Some A/V receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
If the issue is still unresolved, service may be required.
