Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Just Purchased a Whirlpool Fridge Side-by-side?
Purchased fridge, no user manual, it has automatic water and ice dispenser...Is all you do is plug it up??? Just wondering how long it will take to make ice and get water????
  • nucleus93 Dec 28, 2008
    Hey! Thanks! Where does it get the water? Should there be something hooked to the fridge???? If so, my Fridge is not hooked to a water supply.
    THANKS soooo much! I thought so....I don't have an user manual. Is this something that I can do? How do you connect it? Do you know how I can get a user manual?
  • 115 Answers
It will start making ice within 24 hrs you should be able to get water out the door but it wont be cold but it takes 24 hr for the box to get cold and stabilized
Posted on Dec 28, 2008
  • 78 Answers
Yes it has to be connected to a water supply with a small water line on the back of the frig.
Whirlpool fridge freezer
The fridge side is cooled by the freezer side. Try unplugging power, open freezer door and let thaw out/defrost.
Apr 30, 2014 | Refrigerators
Whirlpool refrigerator WSF26C2EXF01 water dispenser not working
This sounds like the water inlet valve has gone bad.. First before u replace it check to see that you have water coming to back of fridge as it could be restricted causing no water to reach the fridge.
Apr 04, 2014 | Whirlpool Refrigerators
The automatic ice dispenser is not working. How can I tell if it is the motor or the switch not working?
On my Whirlpool, the water splashes on the rotating parts and sometimes freezes the maker stopping it. Pull the plug on the fridge, use the hose on a vacuum machine plugged into the exhaust to get warm air to the ice maker or use a hair dryer to warm up the ice maker. After you are sure it is defrosted, plug the frige back in and listen for sounds of the ice maker turning or observe every couple minutes to see if the rotating parts are turning
Dec 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I PURCHASED A WHIRLPOOL GS5VHAXWY FRIDGE AND THE ICE IS NOT COMING OUT OF THE DISPENSOR WHAT IS WRONG WITH THE ITEM
first thing to check is that you have water going on the inside of the ice maker tray simply stick your finger inside and see if there is water if there is no water you would then look at the water valve or the line in the back of your fridge if there is water or rather there is ice inside the tray you would want to remove the ice maker and run the tray under hot water then reinstall to test if this does not work then replace the ice maker hope this helps
Jul 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
User manual whirlpoolfridge freezer 20rid3 sf i have lost user manual
Call Whirlpool. The number should be on model tag inside freshfood. Either upper right or upper left.
Sep 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water drips slowly out of dispenser, ice distribution is fine.
Hi, yes the water line could be starting to ice up; maybe defrosting the fridge will cure the problem. Mine has a coiled tube behind the lower drawer in the fridge, this is where the water line is chilled. Hope this helps if you've not sorted the problem already. Kind regards jb
Jul 02, 2009 | Whirlpool GS5SHAXN Side by Side...
Ice Maker not making ice in new fridge
make sure the metal bar is in the down position
Apr 16, 2009 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
217 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
