Question about Mitsubishi WD-52725 52". Rear Projection HDTV
My Mitsubishi Rear Projection TV does not switch on
My Mitsubishi Rear Projection TV (model WS65807) does not switch. It is about 7years old and sparingly used. I opened the rear panel and cheked out the fuse. I also confirmed that 110 V is coming in to the tV to the fuse, with a mutlimeter
I do not see any resettable button in the front panel. No light comes on when the unit is plugged in. Just a small arching as the plug is inserted into the outlet and a faint hiss similar to connecting any light electrical equipment. Hiss stops right away.
TV does not respond to the power button on the front panel or the remote (no sound or screen lighting up).
  • 365 Answers
I think it may be only due to the damage of some components inside the TV.as you have seen that the 110v is coming in, there is no problem with the current supply and nothing to do with that.next step is to check whether the each and every component gets the correct voltage to wake up or every board inside is working fair.if you are not expert in this work,the better way is to go for a technician and seek for his help also.thank you
Posted on Dec 28, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls check the presence of standby +5VDC from the power supply board. This +5 is responsible for the logic control and general management of the operations of the TV. It wakes up the TV. It is also used for the built-in diagnostics and the auto-protection system.
This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa.
The TV says volume off how do I turn it back on?????
Go into the main menu and look to see if the SPEAKERS are switched off--the model listed is rather old and may also have a internal/external slide switch on the rear of the set.
Apr 24, 2012 | Mitsubishi VS-45603 45" Rear Projection...
57H81 57 in. Rear Projection Television: My Toshiba model 57h81 is 5+ years old. It just s...
I had the same issue with my 57 in. Mitsubishi. I fixed it by buying a new projection bulb. The Mitsubishi manual indicated this was the fix for my Mitsubishi TV. Be advised that new projection bulbs are not inexpensive. My TV works like new once the projection bulb was replaced.
May 03, 2010 | Televison & Video
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Unable to turn tv on and of.
if no parts is available have it converted, since it is only a switch. any switch will serve its purpose as long it has the same power rating
Jul 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My 10 year old 55 inch Mitsubishi rear projection shuts off.
The main board/switch is worn to the point it will not work anymore after a while, I been in the business for years, These are wonderful TV's, yes there are replacement parts but a quick fix your looking for here will be unsuccessful this is the reason I am providing my advice and take a chance on the rating your going to give me. Try www.ebay.com look for people that is saling parts for these TV's.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi
you need to do self test first look in threads and also ctechnicians.com to get error codes.
Dec 30, 2007 | Mitsubishi VS-50611 50" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
