Can't open the door
Jowas1977@go2.pl thx
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
My digidoor2 open and close open
The closing force may make it think the door is hitting an obstruction. Also make sure the door is not binding in the track and all the rollers are oiled and work smoothly. And nothing is obstruction the optical sensor. Thx
Jul 28, 2016 | Building Materials
Cartridge install
Press the cartridge-door release button, and then open the cartridge door. Make sure that the door is completely open.Insert cartridge properly inside, close the door...
For more info pl visit you tube link:
https://www.youtube.com/watch?v=vjmKxIqyjWk
Sep 17, 2013 | HP LaserJet P2055d Printer
I am having a problem with my Craftsman 1/2 HP garage door opener 139-53910. My light bulb does not come on when the garage door is opened or closed as it should. I don't have a manual. Is there a...
Make sure the bulb is good. Unplug the opener and remove the bulb. Use a small screwdriver to pry out on the center contact in the light socket. Replace the bulb and plug in the opener.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I installed an LCW1943TB on my Compaq Presario. When it turns on the background is yellow for my active screens. The desktop also has a yellow tint to it. What needs to me changed to make it white?
right click your desktop back round go2 properties, go2 desktop change your back round to any color or image you like, and go2 themes and select the color tone for windows its really simple.
Feb 23, 2010 | Computers & Internet
I lost my key is there a universal key
Call a locksmith he can make one on the spot. Ask them before they come out though. Quikest way unless you go to the dealer.
Mar 31, 2009 | 1993 Nissan Pathfinder
The washer door will not open, only showing do, or fl
Open the detergent dispenser and feel along the front edge behind the removable cup there is a coloured cord usually red or green, this in an emergency door release, by pulling on it firmly the door will unlock. Power shd be off. This will solve your immediate prob, for the rest pl surf this site. Pl rate..................its important, for me.
Mar 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
