Question about Compaq Presario Notebook
Card reader not working
Sir,
In my compaq presario C795TU laptop i can't read my memmory card.
My memmory card slot name is SD.MS/Pro.MMC.XD.Kindly check and resolve my problem
PRASAD.PK
Mi laptop Dell Inspiron 11 z no reconoce la tarjeta SD
  • Maria, the reader only reads the cards listed below. try another card to see if it reads another. If you open My Computer does the system see the card from that area?
  • The 7-in-1 Media Card Reader reads the following memory cards:
    • Secure Digital (SD)
    • MultiMediaCard (MMC)
    • Memory Stick (MS)
    • Memory Stick PRO (MS-PRO)
    • xD-Picture Card (xD)
    • MMC+
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 02, 2014 | Dell Inspiron 11Z Laptop Computer (Intel...
Sd ms pro mmc sm xd dv 8000 slot is not recognizing card
Try a different sd card,, chances are your card needs to be replaced.. yes they go bad, sometimes very quickly.
Dec 30, 2012 | HP Pavilion dv8000 Series Laptop DVD Drive...
My gateway computer won't read my 32gb sdhc card
If your current card reader isn't compatible with SDHC cards then you need to get one that is. While SDHC cards fit into the SD slot, they care electronically incompatible and won't work in devices not designed for them.
Dec 29, 2012 | Cameras
Sd.ms/pro.mmc.xd
Well if the inbuilt card reader does not recognize the SD/MMC card then we need to perform certain troubleshooting steps which are as follows:
1>click on start
2>In start search box type DEVMGMT.MSC
3>As soon as the device manager window opens up locate an option which reads as UNIVERSAL SERIAL BUS CONTROLLERS
4>There would be a + sign next to the same, click on it and then try locate a driver which reads as REALTEK SD CARD READER driver or JMB38X MS SD SD/MMC xD Card Reader Driver.
5>Right click on that driver and then click on uninstall
6>Locate a tab which reads as ACTIONS at the top, click on it and then click on then click on SCAN for HARDWARE CHANGES.
7>try installing this driver:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-73184-1&lc=en&dlc=en&cc=us&product=3818852&os=2093&lang=en
or
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-79371-1&jumpid=reg_R1002_USEN
Restart the computer and then check
Hope this works.
REGARDS
KEN
Mar 19, 2010 | Compaq Computers & Internet
How does the media card reader work on the side of the hp pavilion dv4. It is supposed to allow for a ms/pro but it just kind of falls in. It almost looks like an adapter is supposed to fit in the slot
The Digital Media Slot supports the following digital card formats:
● Memory Stick (MS)
● Memory Stick Pro (MSP)
● MultiMediaCard (MMC)
● Secure Digital Input/Output (SD I/O)
● Secure Digital (SD) Memory Card
● xD-Picture Card (XD)
● xD-Picture Card (XD) Type H
● xD-Picture Card (XD) Type M
Here's how to use the memory card reader:
Jul 14, 2009 | HP Pavilion dv4-1140go Laptop
Compaq Presario V2000 card slot not reading SD MS/Pro MMC SM XD...Help Greg underdog_greg@hotmail.com
Hi
try to connect your card reader to other PC if they can read!? if not you need a driver for your Card reader to read all card.
Thanks!
Jun 06, 2009 | HP Pavilion dv1000 Notebook
Stuck
I understand that now the Multimedia card is struck in the Media card reader of your notebook and you would like to know how to remove it.
Let me explain, there is no separate procedure to remove the card from the card reader.
Just insert and pull out, if it is not comming out when you pull gently, then you need technician help to remove it.
You need to contact local service center.
Aug 13, 2008 | HP Compaq Presario V2000 Notebook
Memory stick / card slot not reading
hi your card reader conect to laptop & reset ..........then laptop start your card ok.
Jan 21, 2008 | HP Compaq Presario V2000 Notebook
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory StickĀ® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Compaq Presario Notebook Logo
300 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
