Question about Kenwood KDC-MP208 Car CD/ MP3 Player
Wiring problems? I recently installed a kenwood cd receiver kdc-mp208 in a 2000 pontiac sunfire. I have not figured out for sure where to hook the orange and the orange with a white stripe wires to. I am pretty sure the orange wire is for memory and it just need to go to 12 vdc, not sure about the other though. The stereo works just fine but now I notice that I have no dash lights when the headlights are turned on. I unhooked the negative cable from the battery while installing this so I'm pretty sure I didn't short any wires out. Does this orange wire with a white stripe have something to do with this problem? Any suggestions will be greatly appreciated.
  • 15,935 Answers
Http://inform3.kenwoodusa.com/manuals/kdcmp238.pdf
There are no illumination wires on this deck, so the Orange and orange/wht are not used on the wiring harness. Orange wire is NOT for memory. Yellow wire is +12VDC Constant for memory.
If you hooked up the 12Vdc to the orange wire, your fuse for your dashlights have blown. Check your cars fuse panel for a blown fuse.
The orange wires are sending a signal out to radios with illumination circuts. You just sent a 12VDC signal upstream and it collided with the Cars signal and blew the fuse.
Tape off the orange wires, and all will be fine after changing the fuse.
Posted on Dec 28, 2008
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Car stereo installion
I think you left the yellow wire from the kenwood disconnected
Mar 05, 2013 | Kenwood KDC-BT752HD CD receiver
I cant figure out which is the memory wire for the kenwood kdc-mp4028 or where to connect it, please help?
The memory wire is yellow. To hook it up you need to take it to a power supply that is always hot like straight to the battery. You can get the manual on the link below page 28 will tell you how to wire it.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/113/113KDC3028.PDF
Sep 04, 2011 | Kenwood KDC-MP4028 CD Player
What is the wiring diagram on a kenwood cd player? i unhooked stock stereo in 93 pontiac sunbird cut all the wiring and cant figure the wires out on cd player
Scroll down to page 15 on this link i gave you. If you removed the factory stereo, don't throw away the connector that plugs in to the back of the factory radio. Go to wal mart or any car audio install shop and buy yourself the wiring harness for your particular model car and year, it will definitely save you a headache due to the fact that some car wiring systems are wired differently and are somewhat complicated at times. http://manual.kenwood.com/files/B64-3691-00_00.pdf
Jul 02, 2011 | Kenwood KDC-135 CD Player
Installing a kenwood kdc-135 in a 2001 monte carlo ls
Hello, my name is Israel and I will help you. The following should be able to help you out. Please rate and good luck.
constant 12+ orange
switched 12+ yellow
ground black/white
illumination gray/black
dimmer brown white
Left Front + tan
Left Front -
Apr 13, 2010 | Kenwood KDC-135 CD Player
How to hook up a kdc-105 kenwood in a sunfire
There are 3 things you need to purchase for this install. 1) The factory spec install kit. 2) The factory spec additional wiring harness. 3) Antenna adapter.
Find the easied way to remove the plastic cowling around the radio and ac controls. Usually you can locate screws helping to retain the plastic dash parts. Be careful not to break the plastic dash by taking your time and looking over and over the part ofr connection hardware. Once you have located and removed all/if any screws, carefully pry out on the piece you are removing. There are often metal clips on the back of the piece that also help to retain the dash. Once that is removed, unbolt/unclip the factory stereo and slowly pull it out of the dash. Remove the factory harness from the backside of the factory stereo. DO NOT CUT THE HARNESS!! The wiring harness you have purchased is designed to plug and play into the factory harness. All you hae to do is color match the Kenwoods harness with the one you purchased. When wiring the two harnesses together use connectors **** a **** connectors, crimp connectors so forth and so on. If there is wiring you will not be using, take some electrical tape and tape the bare wire. We don't want a short. Once you are sure and have doubled checked that all the wiring is secure and matched, reverse the order of disassembly.
The plastic install kit should replace the factory radio size difference. Just remember to take the metal sleeve tha came with the kenwood and install it into the plastic install kit via the instructions provided. Slide the Aftermarket stereo into the sleeve you just installed. Then you are ready to make all the needed connections. Before you reassemble everything make sure to do a test run with your stereo. If all is well reassemble and jam on.
Sep 10, 2009 | 1999 Pontiac Sunfire
Call constantly cuts in
you must of traped a wire when you have fitted the head unit to the car when you have pushed it into the dash or the call wire is going to earth on something behind the radio in the dash hope you fine it hope ive help you let me now how you get on
May 29, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Problem installing a Kenwood cd-receiver
will this be any help for you. http://12.4.198.133/S-BC7wTd7tyQP/App/Product/Item/Main.aspx?g=300&i=113MP535&tp=5684
regards
riz.
Nov 04, 2007 | Kenwood KDC-MP535U CD Player
Kenwood KDC-MP208 Car CD/ MP3 Player Logo
332 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
