Question about Sony 1GB Memory Stick PRO Duo Memory Card
Wont access memory card
I put my sony memory stick pro duo in my sony cybershot camera and it reads access across the display screen and wont let me do anything when the card is in
  • 1 more comment
  • lap_31c Jan 15, 2009
    Same problem...
    It reads access on screen and nothing else happens... Tried to recover on laptop but doesn't open the memory stick... Please help. Lost my wedding pictures!!!
  • ahmed4mazi Feb 06, 2009
    my memory card is make my mobile so slow and it isnt work even.......
  • cadencemi207 Apr 27, 2009
    I have a similar problem with 8gb. Other cards work fine in the camera and the 8gb one even works when I use a usb connector to load pictures from it to the computer. But, when I put the 8gb card back into the camera, the camera just gets stuck on "accessing" until it finally goes to the camera's internal memory.
When i connect my camera to laptop it sayes that format it first?
what should i do?
Posted on Aug 05, 2009
    Novelist:
  • 151 Answers
I) try to put memory card in any mobile if it working in it is fine, if not your memory is having some password put on it or attached, try to remove the password and then work with it ........
you can remove password by keeping the memory card only in that mobile where you kept the password(only in that mobile through which u kept the password...)
Posted on Dec 28, 2008
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
My Sony memory stick pro duo magic gate mark 2 is not shows images on pc but in my camera, but the photos are visible on Sony cybershot camera
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
May 31, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
Sandisc 4 GB memory stick PRO Duo not working
According to the users manual, the camera does not support above 512 MB cards, however I noticed that there is a firmware update which might address the issue. Go to www.sony.com and support, electronics. Put your model number in the selection box and you'll be taken to the drivers download page.
Feb 14, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Pictures stored on card, and unable to retreive them on camera
Have you tried accessing the pictures via a card reader connected to your PC. It is possible the card is damaged and you will not be able to recover your pics. But it is worth a try. If you do not have a card reader take the card to a camera shop and see if they can see and manipulate the pics to another card, then reformat the card and reinsert it to see if it then reads anmd writes.
Jul 22, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Maximum Memory Stick size I can put into my Sony DSC-N1
Unfortunately, there is no way to change the internal card reader in the camera to accept higher density memory cards. You can find the memory stick compatibility list here: https://esupport.sony.com/perl/support-info.pl?&info_id=12 . Scroll down to the Cybershot N Series camera list. The maximum capacity memory stick is 4 GB memory stick pro or M2 Memory stick Pro. For the Memory Stick Duo, it looks like those have a maximum capacity of 2 GB.
I hope this helps.
Apr 14, 2017 | Sony Cyber-shot DSC-N1 Digital Camera
When i put my card in my camera it reads access across my camera view screen and wont let me do anything can you help me
i) try to put memory card in any mobile if it working in it is fine, if not your memory is having some password put on it or attached, try to remove the password and then work with it ........
Dec 28, 2008 | Sony 1GB Memory Stick PRO Duo Memory Card
Well alot of the time there is a issue with the formating that the camera does on the stick and also when formating it on the computer it formats it another way as well. some in FAT and some in FAT32 this is ushally a error for the most part I would definatly plug your duo stick into a card reader and then go to my computer and the find the drive that the stick is in and right click on it and go to properties and do a error check on the stick to make sure that there is no errors. and if you can defragment after the scan then by all means do it and then format the card and try it and hopefully it will work out to your advantage.
*note this problem seems to only happen with the non branded duo sticks not the sony branded ones.*
Aug 02, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Can't access pictures taken
If you can't access the memory card even with a card reader...your camera is working fine...the problem is ith your memory card (internal problem)...if your warranty is not finished sony will replace that to a new one
PLEASE RATE ME ( FIXYA )................................
May 26, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Sony 1GB Memory Stick PRO Duo Memory Card Logo
497 people viewed this question
Top Sony Electronics - Others Experts
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
