Question about Gateway MT3705 Notebook
Gateway 7320 computer will not go into standby or hibernate
    President:
  • 1,179 Answers
Check the power management settings to see if those modes are enabled. Hope this helps.
Posted on Dec 28, 2008
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Standby/Hibernate
Have you tried or are able to use system restore to go back to a earlier date before this issue?
May 28, 2012 | HP Computers & Internet
No active standby button, hybernate facility not found.
In the control panel, go to performance and maintenance then click power options. Or, right click the desktop and select the screen saver tab, then click the power button. If the hibernate tab is missing, either your hardware does not support standby/hibernation mode, or it is disabled in the BIOS. If the hibernate tab is available, click Enable hibernation to do you know what.
May 07, 2009 | Computers & Internet
When computer goes into standby
Unfortunately this happens a lot with standby. My recommendation is to turn standby off or change the options so it doesn't turn the hard drives off. If you want to change the settings or turn hibernate off go into the control panel from the start menu. In there open the power options. In there you can set all the standby options. Try to set the hibernate option to never first. Then if that does not work try changing the hard drive option to never like i described earlier.
Jan 21, 2009 | Dell Computers & Internet
Question regaurding two different gateway laptops
Hi!
I compared them, the on you have is a good laptop, the one you consider to by is not.
The one you have has on mobile prosessor 2,7ghz, the 450 has an pentium4, that will get that laptop warmer and it will consume mote electricity
The 7320 have 512mb ram and you can upgrade it to 1,5gb ram if you want. The 450 have 512mb ram and thats the maximum it can have.
The 7320 has an 15.4 in TFT active matrix 1280 x 800 ( WXGA ) screen. The 450 has 14.1 in TFT active matrix 1024 x 768 screen.
The 7320 has Intel Extreme Graphics 2 Shared video memory . The 450 has ATI Mobility Radeon M6-P 32.0 MB
In my opinion, the only thing thats better on the 450 is the videocard, and that just a little bit better.
So my advice is..DONT buy that 450, there are better laptops out there for a good price.
I hope the info i gave you helped
If you have further questions, just ask me and i will do my best to help you
Good luck
Nic
PLEASE rate me
Dec 30, 2008 | Gateway 450SX4 Notebook
Laptop 7320 will not enter standby or hibernate
think is it not have good quiality.dont give these things to child
Dec 28, 2008 | Gateway MT3705 Notebook
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Inactive standby option
>I saved myself from a lot of these problems. I set the power button on the front
>of my computer to put my PC into hibernation.
>This is how you do it:
>1. Go to the Control Panel
>2. Open the Power Options window
>3. If Hibernation isn't on, go to the "Hibernate" tab and turn it on.
>4. Once you have hibernation on, go to the "Advanced" tab.
>5. If your computer supports it, there should be a dropdown menu in the "Power buttons"
>area. From there you can make your computer perform a lot of power management functions
>including Standby and Hibernate.
[Reply or follow-up to this message]
Jul 10, 2008 | Microsoft Windows XP Professional
Gateway MT3705 Notebook Logo
56 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
