Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
No Picture on Magnavox 42" Plasma TV
We were watching TV last night with it made a click sound, just as it does as it turns on and off, however we lost the picture and can not get it back. We have the sound, but no picture at all, not even a blue screen. Does this spell the end of our TV? Is there something that can be can? Thank you
  • hchez Dec 28, 2008
    Thank you, We have also just noticed when we have the television on with the sound it turns itself into stand by mode, is this a part of the same problem?
  • Philips Master
  • 5,569 Answers
Plasma displays use a fairly high voltage and the supply for it has failed.
If you want to check on your own, remove the back panel and look for one or two boards with far fewer and larger than average components on it or them.
If two boards are present, the one most obviously related to the incoming AC cord will be the main supply but in some sets, the main and HV supplies may share a board.
Locate the part # and email the manufacturer for a price on repair or replacement.
Posted on Dec 28, 2008
  • Steve Allison
    Steve Allison Dec 28, 2008
    It could be and that is pointing more toward the main power supply which, as previously mentioned, could also have the high voltage circuit on the board with it.
    It is possible to derive the high voltage from a source within the main power supply or provide a separate board for the display.
    It saddens me that so many of us have either dumped or 'donated' our old CRT sets that were dusty inside but working well, to place a new, more expensive flat screen set in its place only to see it die in an inexcusably short time.
Hi , was watching my 42 inch VIORE Plasma TV last night, when I heard a click noise and the picture went immediately but the sound remained fine, I could switch channels but no picture, would you have any...
Check high voltage circuit. This is near where the 120 volt cord is plugged in and a high voltage transformer, where there should be capacitor (or two). Check the voltage - should be 390 to 400 volts. If not less than 390, near to replace the capacitor.
Dec 22, 2017 | Toymax Viore 42 in. Plasma TV
Magnavox plasma television will not turn on, makes
Relays clicking noise you hear.....change caps..you might see visible signs of CAPs being bad....swolen,,, top ready to explode etc.
May 19, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Hi , was watching my 42 inch LG Plasma TV last night, when I heard a click noise and the picture went immediately but the sound remained fine, I could switch channels but no picture, would you have any...
Sounds like a capacitor blew on one of the boards. Can you detect any burnt electronic smell? If the Cap blew on the Power Supply, you can either replace the Capacitor or replace the power supply board. The boards are between $79 and $149 depending where you get it. Some of the other boards, Y or Z Sus, are between $179 and $300. If you can't do it yourself, and with many 42" models selling for $649 to $899, it might be too expensive to fix.
You can find the boards on ebay or shopjimmy, youtube has videos showing how to replace them. Hope that helps.
Feb 15, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Feb 24, 2009 | LG 42LC3R 42 in. LCD TV
LG 42" Plasma - Sound but no picture
HI,
I'll think that either your backlight or de backlight -driver, -supply is not OK.
Kind regards,
Gerard
Oct 21, 2008 | LG 42LC2D 42 in. LCD HDTV
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
558 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
