Question about Apex Digital AT2008 20" TV
Blown fuse inside tv
Need to know what size fuse to get.
  • nancie_t Dec 28, 2008
    thank you for your help.
    Problem Solver:
  • 5 Answers
Howdy Mike-d. here,
Hi nancie_t,
The blown fuse I have in my Apex AT2008 is a 4-Amp Slow-Blow Fuse.
125V-5x20mm GMA-Type.
Good Luck.
Mike-d. out
Posted on Jan 21, 2009
    Problem Solver:
  • 17 Answers
Look at the fuse you pulled out. The rating is embossed on the side or end.
Posted on Dec 28, 2008
I have a Philips flat panel tv.went off last night and know power what so ever.I think it's a fuse but not certain.my tv is 42"What size fuse should I buy?
If the fuse blown.. right next to the fuse on the board it should tell the correct size.. also on the fuse it self on the metal tips it says the size that it is.
Sep 11, 2015 | Philips Televison & Video
What fuse controls the blower motor and cigar lighter
You people need to list the year, make, model, & engine size, when asking a question. It helps when we know which vehicle it is.
All I can tell you right now, is take of the cover to the fuse box, it should be marked on the inside of the cover. If not & your blower motor & cigarette light are both not working & you suspect a fuse,
you will need a test light, clip it to a good ground, then with the key on (motor off) touch the little metal taps that are on each side of where it states the size of the fuse, the test light should light, when you touch each tab, if it only lights on one side, then that means that side is the hit side & the fuse is blown preventing the current from traveling to the other side to feed the power to whatever circuit your testing. One you find the blown fuse, you can pull it & see it's blown
Jan 06, 2015 | Cars & Trucks
Rear wiper fuse is blown again on 2013 mkx
Blown fuses will look dark and smokey, also there should be a map of the fuse locations on inside of fuse door, or just go to Oreilys and ask them...
Jan 09, 2014 | Lincoln MKX Cars & Trucks
The fuse inside was blown and on opening found the blown fuse broken. replaced it and it is working. however the blown fuse was smaller in size while we replaced with a bigger size. does it matter???
you must replace the FUSE with the same capacity for example: you will see in the metal fuse the incription 240vac-15amp see if the fuse is Ceramic or Glass, you CAN not use 125vac,10amp or 20amp, the circuit WILL not protect the electronic system, and will dammed another section. Please rectify this INMEDIATELY.
God bless you
Jul 31, 2012 | Microwave Ovens
'06 VW Polo cooling fan not working - fuse inside fine - fuse on top of battery (5) blown - put in new one and blown again - need bigger size or what?
Don't put in a bigger size. If it blew once, it means something inside the fan has failed. Take a look for any obvious shorts in the wires: Failing that, Take out the fan, and see if it works. Most likely the short is right at the connector, where it vibrates out the most.
Jun 05, 2011 | Volkswagen Polo Cars & Trucks
Toshiba MV13L2 13 in. TV/VCR Combo
it should tell you on the board where you took it out of it usually around 125v/4amp
Feb 02, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
Tv will not come on
HELLO. it sounds like it could be a couple of things why your set will not come on. 1. you could have a blown fuse.on the chassis. 2. you could have a bad power supplly transformer. 3. you could have a bad horizontal output transistor and a bad fly back transformer. it could be one of them or both of them as well as a blown fuse. because the fuse is blown from the horizontal output transistor burning out or the fly back transformer burning up. check and see if you have a burnt fuse, the size iof the fuse will be 5 amp to 6.3 amp fuse on the chassis right inside where the 110 ac cord comes in and hooks to the chassis. the fuse should be right there, look for it. hope this helps you"GOOD LUCK"
Aug 09, 2008 | Televison & Video
Blown fuse
usually these step up transformers are design for one appliance at a time , let me know the brand and model number of transformer so I can get the specs info , does the stereo also shuts down?? let me know AJ
May 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
JVC AV-36260 Is there a fuse in this TV or is it a circuit breaker, if it is where is the fuse / circuit breaker located. I am am electrical engineer, but can not find any specs on the inside of the unit
All modern TV's have fuse devices,some glass,some chemical.
However,a blown fuse comes from a short circuit,which I'm sure
you are well aware.Let's talk diagnosis--What is your set doing
or not doing?? Is it dead?==No "on"?? If there is no bad fuse,the
most common solution is a bad capacitor in the power circuitry
number sequence==900's. Ex..C953    value== 1000mf/35v.
Other caps in power supply may be weak.
2) Check Horiz output transistor---shorted? Look for blown B+
fuse + weak or open C523 1mf/160v in horiz drive circuit.Replace
horiz out with high-quality OEM transistor only.I use JVC only
on 32" size & bigger ( you have 36" ).
  Let me know by rating this solution...thanks...T.
Oct 22, 2007 | JVC AV-36260 TV
Apex Digital AT2008 20" TV Logo
185 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
