Question about Rival FSD201 4-Cup Rice Cooker
Cooker won't stay on
When I set the timer and hit the on off switch it starts off good but after about 30 seconds it turns off. I keep trying to start it and keeps shuting down. Actually when I think about it it never has worked for me. I tried using it right after when i bought it. I then pulled out my old one and put it away. i kind of forgot about til i went to use it again today. Now I can't find the direction book. Thanks Marnie
  • 1 more comment
  • ghohst Mar 12, 2008
    after timer runs it wont start again
  • Anonymous Jun 06, 2008
    Same Problem..... can I order a new power supply unit and do it myself???? My warranty has probably run out.
  • Anonymous Apr 05, 2009
    I have the same problem. Got it for a wedding gift, hadn't used it until 9 months later. I already ditched the box! Now I'm stuck I guess.
    Genius:
  • 1,074 Answers
Your rice cooker has a defect from the time you bought it, you should have taken it back while the warranty was still in effect,but if the warranty is still in effect take it back to the supplier.or have a tech look at it, the problem is in the power supply circuit.good luck.
Posted on Apr 24, 2007
How do I tighten the Timer Knob on my Whirlpool AVM 950 Microwave Cooker Hood Combo?
Look to see if a flat nut under the knob or a Allen nut/bolt that secures the knob is loose--some are drilled into the side of the knob.
Jun 14, 2012 | Microwave Ovens
I need an owners manual for the SCVC651
I couldn't find the specific manual for this, but I did find some basic instructions on a personal review:
"Rival calls this a SmartPot and describes this unit as "programmable". All this really means is that you can program the slow cooker to cook either on "High" or "Low" for up to 20 hours, in 30 minute increments and then it will automatically switch to the "Keep Warm" setting and keep your meal warm for hours. You cannot program multiple steps, such as going from the "High" to the "Low" setting. The red, LCD clearly displays the remaining cook time.
Simply plug in the slow cooker, and then push the clearly marked buttons (with a pleasant, audible tone) to move from "Low" to "High" to "Keep warm" settings. Then push the Timer Button to set the desired cook time."
Hopefully, this helps answer your questions!
Nov 23, 2010 | Rival SCVC651-F Slow Cooker
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
    Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    thank and thanks for using fixya.
    Aug 20, 2010 | Ovens
    Yogurt
    Your yogurt machine is pretty much just an incubator. You can google for yogurt recipes, then you just turn it on, or hit start or set the timer or whatever.
    Oct 01, 2009 | Salton RA5 5-Cup Rice Cooker
    Sony Trinitron won't turn on, Standby/Timer light now blinks 2x
    your power unit maybe going bad
    If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
    Jul 21, 2009 | Televison & Video
    Re: my whirlpool digital oven
    The red key sign is a lock against children. To cancel it you have to hold the two buttons at the same time for 5 seconds (you activate it the same way).
    The STOP sign appears after the cooker switches of after a power cut. You just have to press the left button, and, using the right knob, set the time.
    Jun 24, 2008 | Ovens
    Timer problem
    Sounds like your timer board is fried. Replace it.
    Dec 19, 2007 | Panasonic NN-T774SF Microwave Oven
    Timer Won't Stay Off
    I NEED THE MODEL# AND SERIAL# AND MAKE TO HELP YOU
    Mar 30, 2007 | LG L1204R Air Conditioner
    Rival FSD201 4-Cup Rice Cooker Logo
    223 people viewed this question
    Top Rival Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Ric Shull
    Ric Shull
    Level 1 Expert
    Craig Butler
    Craig Butler
    Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
