Question about Gateway Computers & Internet
Modem for dial-up
Purchased a new gateway dx4710 desktop computer and i cant get my dial up connection to work.I was told this computer only has a modem in it for high speed is this true.
  • 741 Answers
Well I hate to be the one to break the news but their is no such thing as a fast modem. They are all 56Kbps which is slow....the only fast modem is a DSL modem, but that is outside the computer and it gets hooked up with your phone company or your Internet Service Provider. Check the invoice or packaging slip and see if it says "DSL Modem capability"..if so then you are ok but your ISP has to install it.
Posted on Dec 28, 2008
My cooling fan on my video card is not running smoothly. Can I just replace the fan? I have a Gateway DX4710-UB002A.
You will find a new video card much easier and less expensive to replace. The fan isn't made to replace so chances of finding the part is slim and none.
Best of it
Gary @ Fax Ya.
Dec 09, 2012 | Gateway DX4710-UB002A PC Desktop
I installed a new motherboard for a Gateway DX4710-05 + windows vista.CPU will not turn on but i do get a continunous bipp sound.Thank you for your help.
In this case do the following steps .
First Remove your computer's RAM and try to switch on the computer . If even after removing the RAM your computer makes the same continus beep sound then just click the RAM properly and insert it properly.
If again you your the same noise then your RAM is faulty.
Jul 11, 2012 | Gateway DX4710-UB801A (L-1015700R) PC...
Installed a new graphic cards for Gateway DX4710-UB801A, it works for a day, but the next day, it wouldn't turn on, the power supply is not running.
Pull the new graphics card out to see if the power supply will start up, if no change, you will need a new power supply module.
May 11, 2012 | Gateway DX4710-UB801A (L-1015700R) PC...
What is the keyboard command to turn wireless LAN on/off? model DX4710-UB002A
http://support.gateway.com/s/Manuals/Desktops/8513030.pdf
There is no keyboard command. You must setup your Network connection to receive wireless. Refer to the manual above.
Oct 26, 2010 | Gateway Computers & Internet
My new pc Dell Inspiron desktop has no modem built in for dial-up internet connection. Im currently subscribing to a dial-up service provider on another pc, how do I connect to the same dial-up service...
You have to configure Internet Connections Sharing on the PC which has a dial-up service.
1. Click Start - Settings - Control Panel - Network Connections, right click on dial-up.
2. Clik on Properties, click on Advanced tab.
3. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box
After that you must connect the other pc to this one via network cable.
If you don'y have network adapters you have to buy them.
Sep 30, 2009 | Dell Inspiron 530s Desktop Computer...
My modem
Returning the computer to Gateway is the most reliable option, but unless you have the premium grade warranty this will be expensive.
You can buy a replacement from Best buy, but if it is for a laptop I would recommend either an external modem or a PCMCIA modem. Opening up a laptop is a job for an expert. If you have a desktop/tower PC then you can buy an external or an internal Modem, Only but the Internal modem if you feel confident about opening up the PC. The external modem is the safest to buy. You will need to check what connections you have on the back of your PC either a serial connector or nowadays a USB connection. Make sure the modem you buy is appropriate to the service you use e.g. dial up or DSL. The assistant in Best Buy should be able to help you with that.
This should fix it .
Carrie
Jul 21, 2008 | Computers & Internet
Reconnecting phone line
Because the new computers from Dell don't come with modems. You have to ask for them. I found that out yesterday when I was purchasing a new computer for work. Quite frankly I haven't seen a modem on a computer in years.
If there is a modem on your computer it should be a card with two phone jacks. One for line and one for the phone. If you are going to use a dial up connection take the phone cord from the line and plug it into the phone jack marked line. If you dont have a card with two jacks next to each other then you don't have a modem. If you already have a network in the house you can run a network cable to the router.
Jul 04, 2008 | Dell Dimension 8200 PC Desktop
Belkin router and modems
i would suggest returning the router and/or purchase a modem router, as it does away with all the connection problems and the need to click dial to connect as a modem router is always on and does not require a main pc to be on. It will also probably be cheaper than buying a seperate modem.
Sep 13, 2007 | Belkin (F5D9230-4) Wireless Router...
Computers & Internet Logo
79 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
