Question about Panasonic PV-27DF64 27 in. TV/DVD Combo
Dvd Player Problem I have this Pansasonic TV and I've had it a little over a year now. For some reason I play a dvd and after a short period of time the movie freezes/skips/pauses for about 1 min. Then I get the error message saying "Please check disc for stains/scratches? I have tried lens cleaners on it as well to attempt to fix the problem. Is there any advice you can give me? Thanks, ~Kenny~
    Genius:
  • 1,074 Answers
If you had tried more than one dvd disc on the player then you are having a lens problem cleaning wont help.over the years of using the set the lens moved out of alignment there are two small screws at the bottom of the lens, the one to the right is for dvd and the one to the left is for cd dics. adjust the one for the dvd turn it anti clock wise.if that does not work replace the lens.good luck.
Posted on Apr 24, 2007
When I play DVD's my tv screen gets a rectangle box on it, the VHS is fine, it's just the DVD player.
Yes! you are right, this almost sounds like a captions problem, check the DVD/VCR Combo menu, if it has captions turn it off using your remote.
Mar 17, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Toshoba tv/dvd combo. won't play many dvd's. makes clicking sound as it tries to load movie?
Dear Lesley!
It looks, like your DVD lens might get contaminated with dust and/or dirt, which is being picked up off DVDs. Let's try to load music CD, instead or DVD. If it loads well, I will suggest, that your DVD player is at fault and you must give up using it. External basic DVD players are quite inexpensive and easy to connect to your TV. But: if no CD, nor DVD load, the solution might be much simpler: use lens cleaner CD with brushes. good ones might even have a special fluid, which applied to brushes(alcohol based). Just load it into your TV's player and follow audible directions. After couple attempts, your lens should be clean enough to play DVDs. Please, don't try to use any "ear swabs", instead. The lengths is not long enough, plus it may damage load mechanism or get stuck inside. I've seen such a cases lately.
Good luck,
Thank you,
Alex.
Dec 15, 2011 | Toshiba 32CV100U 32 in. TV/DVD Combo
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
Why does my dvd player have two pictures with PSCAN displayed across the screen?
The progressive scan it´s for high definition Tv´s and if you´ve got standard tv need to disable that function
Jul 16, 2010 | Memorex MVD2022 DVD Player
DVD gives an invalid Disc Error
This is quite easily, cause by ONE reason. The thing is, the lens is very very dirty, or had broken, try to replaec it if u can, or try cleaning it with cotton.
Mar 30, 2009 | Lite On LVC9006 DVD Player/VCR
Polaroid DVD Player PDM-0742 not playing dvds
I was a circuit board engineer for the on-chip set. there was a major techical issue with the units but due to the cost of investments by polariod, they decided to sell them to the public anyway. the promblem is in the chip that only works for a very short time before is overheats and the system will show "bad disk"
Jan 23, 2009 | Polaroid PDM-0742 Portable DVD Player
Panasonic PV-27DF64 27 in. TV/DVD Combo Logo
66 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
