Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker in my side-by-side Kenmore elite coldspot does not work
There is no water getting to the ice maker, but there is water going to the water dispenser in the door.  I understand it may be the ice maker valve but am not sure where it is located.
  • Anonymous Dec 31, 2008
    Same problem , no ice only water .
  • bill_955 Jan 01, 2009
    water not flowing to ice maker but water dispencer is working
We had the same problem and just now fixed it. It turned out to be ice in the filler tube. Could not see the ice build up in the tube until we took out the ice maker. My husband put his fingers around the tube for about a minute and squeezed the tube at the top until the ice dropped out. Hopefully this is all that is wrong with yours. Good Luck!!!
Posted on Jan 04, 2009
Same thing. Water dispenser okay but no water to ice...
Posted on Dec 28, 2008
My Frigidaire ice maker dispenses water when I use the dispenser on the door. I have been told it may be a DIODE issue. Does the LPHS2687KF0 have a diode?
Good Morning Jim,
I understand the ice maker is dispensing water when you use the dispenser on the door of your Frigidaire refrigerator, model# LPHS2687KF0. I also see that you have a Diode kit and are not sure if it would be this that is needed or a water valve that would be needed. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine what is causing the ice maker to dispense water. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire PLHS267ZA Side by Side...
Water is not getting to the icemaker. however, it is dispensing at the glass tap
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
When your ice maker dumps and refills with water it will come out the water dispenser with the wires swapped. If it doesn't then I would have to blame it on the solenoid.
If the lines are the same size you can also swap them around to do this check.
Water inlet Valve
You can disconnect the line coming out of it and try the water dispenser to see if the valve is working. If it's getting power it should click when you try it and water come out.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Dec 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water dispenser and ice cube maker stopped working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
A strainer before the inlet valve can also get stopped up restricting flow.
Apr 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not make ice anymore. appears the tray is not filling with water. door water dispenser is still working
Apr 24, 2010 | LG LRFD25850 French Door Refrigerator
It makes no ice cubes, but water still comes through door dispenser. Why? There appears to be no water getting to the ice making mechanism, however water is still coming out the door dispenser.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Nov 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water going into door for dispensing or ice maker mod# MRS26LJ
I'm not sure what you damaged with heat but- Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws OR
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Aug 08, 2009 | Frigidaire FRS26H5AS Side by Side...
The in-door water stopped working. The ice maker still gets water, but there is no water coming out of the door dispenser.
You more than likely have a bad water valve. Unfortunately, the water valve is a double valve ,one side services the ice maker,the other side the water dispenser.Even though the ice maker is getting water the whole valve has to be replaced. Hope this helps
Jul 30, 2009 | Whirlpool ED2GHEXN Side by Side...
Ice maker goes through the process but no ice is produced water
If you're not getting water to the ice makerTry swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
A strainer before the inlet valve can also get stopped up restricting flow. ice maker
Jul 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
413 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
