Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
I do have a problem with Jandy Aqualink System
When temperature outside is in the freezing range the System activates the pump yet it immediately shuts down and the whole cycle on-off is running continuously with the clicking sound. What can cause this problem?
  • 22 Answers
I would lower the freeze setting. It sound slike you are hovering around the temp set for freeze and that is why it is turning on/off. Go into the freeze mode settings and lower it as you would a heater setting.
Posted on Dec 30, 2008
Freeze protection temperature in wrong
go into menu then find freeze protect it will ask which auxillaries to be selected select with an x in front then set temp for freeze protect
Mar 19, 2014 | Pool & Spa
Freeze protection on when temperature is 80 degrees
Your air temperature sensor may be broken. Does the display show the correct current air temperature? You can go outside and put the system in service mode. That will shut the pump off. Then you can disconnect the air sensor and see if the pump acts right after putting it back into auto mode.
Mar 19, 2014 | Jandy Aqualink Rs4 One Touch Control...
Aqualink freeze protection
go into system set up find freeze protection highlight what pumps and accessories you want to protect and what temp to activate
Jan 17, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I've got a Jandy PDA, PS4. How can I set the Freeze Protect below 34 degrees?
It doesn't set below the freezing point. That is exactly the point of the minimum setting of 34 degrees - just above the freeze point. If it would set below that temperature it would freeze.
Rod
www.uspartscenter.com
Jan 25, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Outside tempeture is wrong
If you let our a pretty reesty **** it should heat up things and that outside temperature should rise pretty quick.
May 21, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Connecting problems
Installation
The scripts communicate with the Jandy system through a USB Serial Adaptor (e.g. the Keyspan USA-19HS USB Serial Adapter) connected to the Jandy Aqualink RS Serial Adaptor.
In order to use these scripts with SerialX, you will need to separately download and install SerialX as a Scripting Addition. As currently written, you will also need to determine the exact name of your serial connection and edit the following statement in both scripts:
property SerialConnectionName : "/dev/cu.USA19H47P1.1" -- Replace "dev/cu.USA19H47P1.1" with the name of your USB Serial Adaptor.
After editing, drag the Jandy Aqualink attachment script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Attachments
and the Jandy Aqualink background sync script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Background Tasks
Initiating use of the background script is typically accomplished by establishing a Trigger Action that activates on Indigo Server restart.
Usage
Assumes a Jandy Aqualink RS-4 or RS-8 Pool/Spa combination with auxiliary 1 set for pool light and auxiliary 2 set for spa light.
Unlike the previous version, the background script will now automatically execute periodically after being initiated (typically with a Trigger Action that activates on Indigo startup), will create variables as needed, and will update the status of those variables. By default the updates occur every 30 sec for most items using a single "#LEDS?" command, and every 30 min for the temperatures, with error detection if something does not update correctly. If the Spa is heating, temperature updates default to every 2 min. Variables created include AirTemp, ErrorFree, NextTempUpdate, PoolHeatEna, PoolHeatOn, PoolLightOn, PoolPumpOn, PoolSetPoint, PoolStateOn, PoolTemp, SpaHeatEna, SpaHeatOn, SpaLightOn, SpaSetPoint, SpaStateOn, SpaTemp.
Nov 22, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have a Jandy AQUALINK RS TELELINK KIT outside and I have an inside Rs6 control panel as well. The weirdest thing happens when the temperatures outside reach over 80 degrees. My RS and inside control...
power supply is overheating when it cool it comes back on replace or when it goes off see if you have 24 volts ac if not bad transformer if 24 volts check for bad wires
Jul 07, 2011 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
127 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
