Cooling fan
I already clean them but if you turn it on with the power supply button, it only turn on green leds for a few second and do not start the computer!!!! So do I need to replace the fan and the thermal cooling device??? Kind regards. Armando [email protected]
SOURCE: dell Latitude 131L bios password
I got my Dell Bios & HDD Master Pasword within a few minutes from http://www.bios-password.kickme.to/
SOURCE: hi i have a dell
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
