Question about Brother MFC-8660DN All-In-One Laser Printer
Brother 8660DN The Brother 8660DN will not scan with the Paperport software included. Says it cannot connect to the twain device. It will print wirelessly over the network but wont scan. Can you help?
5 Suggested Answers
T-Mania
  • 42 Answers
SOURCE: cannot communicate with twain devise
I suggest using ISIS drivers instead of TWAIN. I have always had trouble with the twain drivers failing especially in paperport ive found the ISIS drivers to be much more stable.
If you do require TWAIN though best way to fix is un-install the software that the TWAIN driver came with and re-install it. Unfortunately thats the easiest solution.
If you want to try the isis drivers they should be on the cd that you used for the twain drivers just select isis instead.
Let me know if you need further assistance.
Posted on Mar 23, 2009
SOURCE: OCR problems for Brother MFC-8660DN with Vista 64bit
You are correct in that paperport 9 will not work on Vista and paperport 11 is the alternative. I called about a similar model and the guy at Brother told me that paperport 11 is included on an updated cd from brothermall.com for some models. It was only about $3 so you might want to check for your model. Hope this helps.
Posted on Jul 08, 2009
SOURCE: won't scan
This MFC works fine when hardwired to the network - eg LAN or USB connection. Wireless setup straightforward but you will encounter problems if you ever shut off the printer as it will appear 'off line' and there is no way, short of reinstalling software or spending countless hours of wasted time, trying to reestablish connectivity. If you like the printer and scanner and fax then ONLY attach hardwired to your network. Don't bother with Brother support as they will only respond with an extract from their manual on setting up the system...the answers are no help.
Posted on Apr 18, 2010
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
How to scan from a 4800 brother
Once the drivers for the printer/scanner are downloaded from Here and installed you can scan a couple of different ways.
First is to use the scanner software (ScanSoft™ PaperPort® LE for Brother) on the original cd. If it is not installed already, install the software from the disk. If you do not have an original disk, you can obtain one from Brother for a fee.
Second is to use a different method/software for scanning. Since the scanner is TWAIN compliant, you can use any software that can import from a TWAIN compliant device. Since it is common,.. you can use Microsoft Word or Publisher (Example: from Word XP - from the top menu, click on Insert - Picture - From Scanner or Camera then select your Brother 4800 from the list)
If you dont have Word or cannot obtain it, you can download and use the latest version of openOffice for free at openoffice.org Here
With either method,.. you will have to make sure the drivers are installed for the printer/scanner.
If you need any further instruction, please comment on this and I will answer your questions
Feb 08, 2010 | Brother MFC 4800 All-In-One Laser Printer
My PaperPort Scanner Program (disk that came with my Brother DCP-120C) will not download to my new Vista Operating System. Cannot download full program at Brother website, either. (It's missing the...
Well, you purchased your all-in-one machine some time ago and it didn't include Vista-compatible software.
PaperPort is a commercial application, available from it's developer company; it's simplified version was delivered with the printer/scanner as bundled software.
As it is not a property of Brother, it cannot be made available for download on their website (as opposed to Brother drivers & utilities), because everyone would be able to download a commercial product without paying for it, that's quite understandable.
I would suggest contacting Brother support (e-mail or hotline) and asking for a Vista-compatible CD for your printer, specifying it's serial number.
Dec 02, 2009 | Brother DCP-120C All-In-One InkJet Printer
Errors when scanning via all methods
You just didn't set up the scanner function, please reinstall the software and restart before you use the scanner.
May 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Apr 11, 2009 | Brother MFC-8660DN Network Mono Laser AIO...
Cannot communicate with twain devise
Mar 22, 2009 | Brother MFC620CN Home/Office Color Inkjet...
HOW DO I SCAN?
Hi, normally, if you have installed the complete driver set, the easiest way is to run a program with scanning capability i.e. photoshop, or word. the software normally given with a scanner is a 'twain' which becomes linked to the photoshop program. If you have MS word (I'll use this as an exAmple ), ensure the scanner software is installed, the brother switched on and connected to the computer correctly click Insert select picture then scanner - (or it may say twain). At this point the Brother mini program - the 'twain' should start and then follow the scanner instructions and a scan of whAtever you have selected should be inserted into the word document. Bit of trivia - TWAIN stands for Tool With An Interesting Name - yup it really is!.
Feb 12, 2009 | Brother MFC 7840W Printer
What are the instructions to scan using Brother DCP 1000? I laid the docment face down and pressed Scan To and nothing happens but showing another selection in the glass window.
To Scan on Brother DCP 1000 you need to click on the "Paperport" Icon on the desktop. Then Click on "Twain." Lay your document to be scanned face down on the scanner glass. Press the "Scan To" button on the Brother DCP 1000 printer. On the "Twain" window click on "Start." Note: When I clicked on "Start" it initially scanned blanks. I clicked on "PreScan" and saw an image. Then I again clicked on "Scan" and it worked. I named each document I scanned and saved them in a folder for later use.
Jul 31, 2008 | Brother DCP 1000 All-In-One Laser Printer
Brother MFC-8660DN All-In-One Laser Printer Logo
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
