Question about Sony PS-LX250H Turntable
Sony ps-x7 cueing arm
Cueing arm does not raise/lower the tone arm
    Sergeant:
    Novelist:
  • 327 Answers
Check out if something is blocking it to raise.and also turn off and try again quickly to raise.tap the sides and check out.
Posted on Dec 28, 2008
When I move the arm and needle over, why doesn't the arm go down?
Arm and needle? Sounds like a turntable, not a sewing machine. There's typically a 'cueing lever' that controls up/down. Pull that lever forward and down to lower needle to record.
Jun 02, 2015 | Sewing Machines
How do I turn a technics Quartz SlQ200 on
Assuming it does not need repair, you should be able to slide cueing lever to the right (raising arm), then place over the record and the platter should start turning. Just slide cueing to left and needle should gently drop on the record. Just press stop button to return the arm and platter should stop/turn off.
Oct 08, 2014 | Audio Players & Recorders
Turn table arm will not move freely, table wont turn, cueing light bleaking
I would need more information, starting with make and model number. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 25, 2013 | Audio Players & Recorders
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
I have a Garrard DD75 direct drive turntable. The cuing mechanism will not function.
Every answer here is wrong. Just plain wrong. It's electronic cueing via solenoid control. There are no cams. levers, or any sort of automation, except for the auto lift on the lead out grove. Voltages to the solenoid must be checked. Capacitors that frequently go on these models must also be checked. If you can live without cueing, disconnect the cueing cable (much like a bicycle brake cable) and your cueing will set to off until you can sort it out.
Jul 21, 2012 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
TONEARM DOES NOT RETURN AT FINISH OF RECORD MODEL PS-X7
http://www.youtube.com/watch?v=PS6g9rQRF9M The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own.
Jan 31, 2011 | Sony Audio Players & Recorders
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Cueing Problems on Technics SL-1300MK2
Usually the damping fluid is to let the tone arm lower slowly, lifting is usually a mechanical link. Read THIS.
Hope that helps...
Geno
Apr 01, 2008 | Audio Players & Recorders
Panasonic turntable sl h205
Check the belt and the cueing mech, could have siezed.
John w
Feb 12, 2008 | Audio Players & Recorders
Sony PS-LX250H Turntable Logo
190 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
