I'm having out of focus problems while taking videos. I'm taking videos of youth ball game. The video comes out fuzzy and not focused... it comes in and out of focus, but mostly out of focus. I didn't have any problems with my older canon elf camera.
SOURCE: lens stays open, won't retract when camera turned off
If your camera is still under warranty, the best thing you can do
is to take it to the nearest official Canon repair shop and Canon should
fix it for free.
If your camera is out of warranty, or if Canon refuses to repair
it for free (happens sometimes if for example they suspect the
camera has not been treated properly) you can try some of
the methods listed here to repair it yourself. These simple methods
have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,
then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry
compressed air (20 lbs) set the tip between the lens turret and the
camera body and turn on the air while moving the tip around the lens.
It should remove all dust and sand. Turn the camera on and it should
function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very
often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and
the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to
fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a
"click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the
camera off. Take the camera in one hand and with the other gently take one part of the lens and gently
move it round in a circular movement. Do so with both sections of the lens. You will hear a "click"
as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning
the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and
off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)
It is a great guide with pictures and it can be found here.
regards
iversh
a very helpful rating is apreciated for answering ur query.....
SOURCE: Canon Powershot SX10 IS auto focus unreliable
I don't this its an error. I have used this Canon SX10 IS Camera for nearly a year now I haven't had this kind of problem.
Usually auto focus take few seconds to focus on object depending on distance and lighting. That might be the problem ?
SOURCE: Our Canon Powershot SD 780 is having a focus problem.
This might be a problem with the lens, I'm not exactly sure but I will get you in the right direction. There's a great site that just specializes in these Canon Powershot problems and they're terrific to say the least. If you go to camerasandparts.com you'll see your exact problem there for the canon powershot sd780is model. That should get you in the right direction to fix this problem. I really hope you can get help with this.
SOURCE: auto focus blocked Canon Eos 1000D
Try cleaning the contacts on the lens and body where they meet with a cotton swab lightly dampened with rubbing alcohol.
SOURCE: My Canon PowerShot SD1000 won't focus. Most
View is not get displaying in the screen when i select other than Easy mode.If i select auto mode it is displaying only the black screen.Any idea why it is like this?
3 Points
Why cant I play 8 ball pool?
