Question about NetGear WGT624 Wireless Router
NO INSTRUCTION ON HOW TO INSTALL
I PURCHASHED TODAY A NETGEAR ROUTER WGT624NAR AND ALSO A LAPTOP IALREADY HAVE PC SO THEY SUGGESTED I GET IT SO I COULD PICK UP MY INTERNET OFF THE PC THE LAPTOP IS WIRELESS
Think this might be what u r looking for
fingers crossed
http://kbserver.netgear.com/pdf/wgt624v3_ref_manual_25Apr05.pdf#xml=http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=867657&action_code=6&highlight_info=352321916,13877,13886&turl=http%3A%2F%2Fkbserver.netgear.com%2Fpdf%2Fwgt624v3_ref_manual_25Apr05.pdf&answer_id=118224485
it is 148 pages pdf so might take a while to display but then you can just download it when loaded :)
Posted on Dec 28, 2008
Netgear router N 300 cannot connect to the internet using laptop
There are many router related settings on NETGEAR wireless router and if these are not configured properly, then issues such as router not connecting to Internet might come up. All NETGEAR wireless router users facing router not connecting to Internet are suggested to verify the router related settings such as access points and reconfigure them if required. Users are also advised to check the firewall settings on the system and ensure that they are not blocking the connection.
Jul 03, 2011 | Computers & Internet
NetGear Wireless Router and NewGear WG111 Adapter
I imagine you bought the WG111 Kit. It could but throught the Router and/or the adapter. Uninstall all netgear software and drivers. Unplug the adapter. Reboot machine. Plug the adapter in and install the software drives. Basically your starting over. This will take the quess work out of trying to repair what was lost. After reinstalling go to this web page to configure the SSID,IP and adapter. http://kbserver.netgear.com/kb_web_files/N101179.asp
Jun 27, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
CAN'T CONNECT TO NET BOOK WIRELESS BUT HARD WIRE PC WORKS
Try RESETTING the Netgear router and configure it again.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 17, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
How do i install a netgear wgt624nar router
Hi slick9,
I think your referring to the software installation for the hardware. If you didn't have the hardware, then you wouldn't have the router. So, with that assumed, here is a link that you can get all the manuals, software and documents on how to start that baby up. HERE.
Good Luck, and Happy Surfing.
Mark
Please don't forget to leave me a rating based on your experience with this Solution.
Mar 27, 2009 | NetGear WGT624 Wireless Router
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
Netgear wireless router WGT 624v4 not accessing some websites
if the router was the problem, then no site would be accessible from either of the problem pc's.
unless the webkinz site is being blocked because it contains active scripts. check the configuration page for the router (usually 192.168.1.1) and switch off any active firewall / security applications running on the router.
May 30, 2008 | NetGear WGR614 Wireless Router
Netgeardg834g v3
find default gateway put into your web browser and log in
use rj45 cable to do this
any probs post it back here
Mar 20, 2008 | NetGear DG834G Router
How to install?
Go to netgear.com and in the support section you can download drivers and instruction manuals
Feb 12, 2008 | NetGear Super G WGT624SC Router...
Wi -Fi usage in my laptop
Try a third time (every time I go into my own network places for netgear I loose this fixya page -sorry watch for duplication).
Go into "start menu" then click on "my network places" then click on anything that says "netgear router" if its there, click on this and it should bring you to your password for netgear, click this with your password and this should bring you to your main page of your Netgear Router software programing.
Click on "connection status" if it says "success" under "negotiation" then its working OK. If you don't get "succes" then you have problems and I recommend you ring the Netgear service number written in your instruction papers in your old modem/router box they are usually based in Malaysia and very helpful.
Best wishes,
Speedy123
Dec 17, 2007 | Toshiba Satellite A105-S4334 Notebook
Netgear installation
have a look at this site it will help you http://www.lycoming.edu/acad/Netgear%20Wireless%20Router%20Setup.htm
Sep 17, 2007 | NetGear WGT624 Wireless Router
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
56 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
