It's about our westell model 327W, i talked to belkin wireless and advised me to ask the manufacturer of wesley 327w to change the channel and ssid so i can go online, belkin did everything already and also verizon, the problem is in the signal. i hope you can help me..
  • Tom Arsenault
    Tom Arsenault May 11, 2010
    Could use more info on this. Is your antenna connected? What os are you using? Did you delete the temp files in internet explorere? What happens when you type 192.168.1.1 in your navagation window in the browser?
  • 104 Answers
What do you min signal? you cant connect to the router or you can connect but can go online to the net? check your settings specially WAN or check your ISP
Posted on Nov 29, 2009
My grandpa set up our wireless network a few years ago, but bless his heart, he passed away just this year and we forgot our WEP key and we need to reset it or just get ahold of it so the family can access...
Sorry for your loss.
  • Note: Resetting your router to the factory defaults not only changes your gateway user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your gateway to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and network encryption key.
To reset your VersaLink 327W gateway to the factory settings:
Hold the reset button on the back panel of the VersaLink gateway for 30 seconds.
  • All your settings will be lost including network encryption information, MAC Address filtering information, and any SSID information you have entered.
  • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  • You will need your user name or password to reconfigure the unit..
Your VersaLink 327W gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | Westell Wirespeed VersaLink...
My westell versalink 327W router works when my computer is connected to it but it is not sending out a wireless signal
Try the following:
Check if wireless is enabled on the router.
Check if the wireless switch (if any) on the computer is on.
Check if the SSID broadcast is enabled.
Try a different wireless channel (6 or 11).
Hope this helps!
Nov 26, 2009 | Westell Wirespeed VersaLink...
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
May 29, 2009 | Westell Wirespeed VersaLink...
No wireless connectivity with Westell 327w
on the back of the modem is a reset button. try resetting and bridging the modem again.
Apr 09, 2009 | Westell Wirespeed VersaLink...
My brother just gave me a Westell versa-link model 327w router. there isn't any instruction/opeartor's manual with it. is there a web site with instructions on how to go about hooking this up? Thanx Wayne
The 327w router is distributed by Verizon, an internet service provider. On their website you find tons of info on this model.
Go to the Verizon support page and enter
<westell versalink 327w> in the search field.
Furthermore here some interesting info for you:
Westell versalink 327w Quick Start Guide (700k)
Westell versalink 327w User Manual (10M)
Cheers
Critter
Dec 26, 2008 | Westell Wirespeed VersaLink...
Westell 327w channels
Type in http://192.168.1.1 in your browser window, this will take you to the Westell Home Page (your router). There are tabs at the top, select Configuration>Wireless>Basic, this will open a Wireless Operation Window. You will see Channel in the 3rd box down. Click on the arrow to change the channel, then click save at the bottom. Close all windows and X out of the browser.
Oct 18, 2008 | Westell Wirespeed VersaLink...
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
56 people viewed this question
Alun Cox
David Payne
David Payne
