Question about Acer AL1916W 19" LCD Monitor
When I turn on my computer I getting no signal to the monitor.
  • Anonymous Jan 02, 2009
    I have the same problem. Turn computer on and no signal, turn computer off wait a while and monitor comes back on for a short period. Changed out the cable same problem
  • salvatore spatola May 11, 2010
    I THINK YOU HAVE TO CHANGE THE CABLE FROM MONITOR IT
    HAS A CORRUPTED WIRE - IT MAY BE  I HAVE TO ASK IF YOUR MONITOR STADING ALONE GO ON   DELFO
I connect my monitor to my computer and I recieve no signal but my computer screen work just the other day, this problem come about when I disconnected my monitor to view on another PC. And now I rec onnect it to my computer and I don't get any signal.
Posted on Dec 29, 2008
The monitor turns on but says "no signal"
Usually this means either your cable isn't connecting properly to your computer or there is a compatibility problem between the monitor and the computer. Are you getting the "no signal" message AFTER you have connected the machine to a working/ turned on computer? Because the monitor will ALWAYS say "No signal" if it isn't hooked up to anything. Also, you will want to verify that none of your pins (from the end of the cable) is missing, and that your cable is firmly seated into the port on your computer. Other than those things, you really need to say a lot more than just, "The monitor turns on but says 'no signal'" for anyone to be able to assist you.
Feb 17, 2014 | ViewSonic VA721 17" LCD Monitor
Acer flat screen monitor
acer monitor v193hqv power supply regulater ic burn so iwant circuit or ic no part no ic 802 problem plse solution
May 03, 2013 | Acer S202HL LCD Monitor
How do I turn my computer computer monitor on
the signal out of range error is usually down to the screen resolution being output from the graphics port is not supported on the monitor.
if the monitor won't turn on and all the leads are in the right place then it's probably broken.
Apr 13, 2013 | Computers & Internet
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
Hi there. My monitor has been working fine up to yesterday. I have all connections plugged in and i turn on the monitor and then the ACER sign comes up and then it says No Signal. and then the blue light...
Your monitor is fine, the problem lies with your computer. Your monitor is not receiving the POST signal from your computer. I suggest you remove your computers graphics card and plug your monitor cable into onboard graphics, then power up and see if the monitor gets a signal. If it does then it means that your graphics card has stopped working. If you still don't get signal then I suggest you take your PC to your local computer shop and get a qualified technition to have a look at it just in case the motherboard is damaged. You can also try out your monitor on another system just to be sure.
Feb 12, 2011 | Acer X233H 23" Monitor
My neighbor has a monitor that won't turn on. When it is turned on, it flashes <monitor going to sleep" That is all it does and we can't get to the desktop to try and correct this.
That means that the montior is not getting a signal from the computer. Have you tried plugging another monitor into the computer. Really the only way to troubleshoot the problem is to hook another monitor to the computer to see if the video card is outputting a signal. If it doesnt work with a known good monitor, you'll know that the monitor is bad.
Jan 29, 2011 | Compaq CV 7500 17" CRT Monitor
ACER AL1716 - no signal Whenever i turn my monitor on i get the no signal message. Why is this?
make sure the monitor is turned on, if yes check the signal cable of your monitor
Dec 21, 2009 | Acer Computers & Internet
SyncMaster T200 won't respond after turning it off and back on.
i also got this problem..
do you have the switching anolog/digital thing?
that he doesnt know which he(t200) needs to pick?
Feb 05, 2009 | Samsung SyncMaster T200 LCD Monitor
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
Acer AL1916W 19" LCD Monitor Logo
152 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
