Question about Sony KV-35S42 35" TV
Sony TV video shows double picture with line down the middle
KV-35S42
Regular cable picture is fantastic. Any ideas? Tried S-video & regular red, white, yellow audio/video plugs using video 1 and/or 2, same problem persists.
I scored high in mechanical aptitude so not afraid to take the back off & take a look if I know what to look for.
Thanks//deborah
SOURCE:
techman
  • 3130 Answers
SOURCE: SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Posted on Mar 25, 2006
SOURCE: sony KV-35S42 35''tv blink on@off Needcodes for remote rm-v3o1
http://www.docs.sony.com/release/KV32S42.pdf
Posted on Dec 28, 2008
SOURCE: blinking screen
My Sont Trinitrtron is flashing off and on.
Posted on Jan 26, 2009
  • 7 Answers
SOURCE: My Sony KV-32HS420 Trinitron Wega TV will turn on
You have what is commonly known as a shutdown problem. It's an overload in one of the internal circuits. It needs to be looked at by a professional tv reapir person.
Posted on Nov 03, 2009
  • 74 Answers
SOURCE: My Trinitron KV-35S42 picture folds up.
Hi this fault due to a capacitor in the frame (field) output stage going low value / the one to look for is a 680uf 63v ( might be 50v) it is mounted to the right of the frame out put ic.Hope this will help regards, windyhouse.
Posted on Nov 14, 2010
Testimonial: "Thanks, I'll try it Richard"
Sony kv 35s42 sound but black screen and constantly blinking stand by/timer red light
Your vertical IC will need resoldering. If you can take this board out and inspect the pins under the vertical IC, you will see rings around the IC. This is a common problem for you model of TV. Hope this helps...show a few hands of support.
Dec 14, 2010 | Sony KV-35S42 35" TV
Double picture on start up
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the coursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of syncs.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Good luck...
May 29, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lcd goes to standy
Hi
I need to know exact model number of your Sony TV to diagnose problem.
Question shows its KV-35S42 that is CRT tv.
Thanks.
Jan 19, 2010 | Sony KV-35S42 35" TV
Sony kv-35s42 35" tv picture blinks off and on
my best advice would be to check power supply for faults, bad capcitors etc to r/o the possiabilies of a power failure.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | Sony KV-35S42 35" TV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Picture Problems
You did not mentioned about in which source watching the Tv. If it normal cable Video if section may failure. Or from AV source CRT board problem.
May 19, 2008 | Sony KV-35S42 35" TV
Sony kv-35s42 no picture, good sound timer light flashing
Usually, the CRT is bad......re-juvenation is a temporary fix at best........try adjusting screen control on CRT socket module.
Only other possibility is solder pins of vertical output IC.
Mar 20, 2008 | Sony KV-35S42 35" TV
Check first for bad solder on the vertical IC, Im not sure for your set as I do not have the service manual, but it may be location IC301. If after resoldering it does not fix it you may have to replace it and you should replace the electrolytic capacitors in the vertical section. Hope this helps. Don
Jul 31, 2007 | Sony KV-35S42 35" TV
Sony Tv kv 2584 A5
There are no adjustments for this problem,if the unit has been working good for 3 years and suddenly gives you this pix is time to call a qualified technician,among many reasons you might have loose solder conections in the horizontal drive circuit or poor regulation problem in the power supply,if you dont know how and where be safe and call a Technician.
Aug 30, 2006 | Sony KV-32S26 32" TV
Sony KV-35S42 35" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
