Question about GE Energy Star WCVH6260F Front Load Washer
THANK YOU! I was faced with a shredded gasket on our GE washer, a replacement gasket, and a one week wait time during Christmas for a repairman. Your instructions regarding the GE front loader were perfect. Basically you talked us through disassembling the unit. Now I need to deal with the fact that we have bought a lemon! rick@dolish.com
  • uga2000 Jan 06, 2009
    We just bought the same washer/dryer the Saturday after Christmas.  We have had problems with both.  HORRIBLE.  I am so mad that we spent $2k on this JUNK.  GE is scheduled to come out this Friday.  We purchased the set at Sears on our Amex.  We are wondering if anyone can help.  They are not lemons, they are just junk.
Same problem here and Ge refuses to fix no charge it is clearly a recall sitition they are trying to avoid the drum is out of round on ours only 1 1/2 years old smoke was actully coming out of it does someone have to have a fire b-4 it is recalled ( or how Many fires will it take ) Very unsafe !!!
Posted on Jul 08, 2009
Tip
I just want to say THANK YOU SO MUCH!!! This fix worked on our GE WBVH5100HWW...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you.
on Feb 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Why is my Samsung washer smoking during the spill cycle?
My Samsung washer has the same problem. Looking at it the gasket is being shredded by the drum and the rubber is burning. If it smells like burning rubber that is probably it. I do not know what caused this but I am going to just replace the gasket and see what happens
Apr 21, 2012 | Samsung Washing Machines
Refrigerator will not hold temperature lower than 44 degrees!!
I bet it's a GE Monogram? I have the SAME problem. Our refrigerator is stuck at 44 degrees. It was stuck at 47 degrees, but after 6 visits from the repairman we now have it down to 44 degrees! At first we didn't realize how bad it was, and we were eating food that was making us sick! My daughter was admitted into the hospital from severe intestinal problems and without getting into details... this has cost her health, and tens of thousands in medical bills.
We have thrown out a ton of food. The repairman has replaced a bunch of parts including a fan, a thermostat, replaced a switch, cleaned, checked the gaskets, replaced a thermostat control device, and possibly other stuff as I can't keep track anymore. He's has been coming 2-3 times per week for the last 3 weeks. And now says the ONLY thing it can be is a "leak" in the copper line. Since it is a sealed system he has to tap the copper line with a valve to check the pressure, and that valve will always have to stay in place once it is tapped. And we will have to have the freon filled every so often because valves will slowly lose the freon over time.
This GE monogram is suppose to be a top of the line GE appliance. Our entire kitchen is GE Monogram, and we have had many many problems with most all of the appliances. The dishwasher was replaced at approx. 4 years due to over priced service calls, and super expensive parts. GE wanted close to $300 for an upper dishwasher rack. It was less expensive to buy a new one.
Don't these appliance manufacturer's get it? They may save money on the manufacturing side, however they lost a customer for life. Not only did they lose me, they lost my daughter, my son, and my grandson.
These GE appliances that are built to fail end up filling up our landfills. GE should be embarrassed.
Possibly have your repairman check the copper line for leaks? We're waiting to see today if that will work.
Apr 27, 2010 | Sub-Zero 650 / O Bottom Freezer...
Replace rubber gasket
Replace the machine with a top loader and you'll never have a leaking gasket again! Worked at National Linen for a while and the floors had drains in them and were always wet! Needless to say the pros have the same problem you do! ;)
Apr 22, 2009 | GE WBVH6240F Front Load Washer
GE Adora Frontload Washer shredding clothes
We were having the same problems with ripped clothing and longer cycles. Our rubber seal by the door has ripped twice now causing massive amounts of water to run out. I learned through other threads that many people are having these problems and was told that zipping up zippers and turning jackets and clothing with big heavy stuff on them in side out to protect from ripping the clothing and the rubber seal. I removed the panel on the front bottom of the machince and there is a small gray cover that housed the coin trap. Mine was clogged and once I cleared that out, my cycle times got better. I hope this was somewhat helpful. We definitely won't be purchasing another GE front loader!!
Mar 29, 2009 | GE WSXH208A Front Load Washer
GE Washer
have they checked the door lid switch?..it could be intermittent also because if the switch is not close, it would not drain and spin anymore. try to bypass the switch temporarily by shorting it out then use it . becarefull because you can now open the door while it is spinning ad it is very dangerous.
Feb 17, 2008 | GE WPRB9110WH Top Load Washer
Torn clothes
I've had this probelm as well and I suspect it to be the gasket that goes around the opening of the washer in your case(s). Mine is torn nearly halfway around and I believe the clothes are getting caught there. I called in for service two weeks ago but they keep telling me that the part is on backorder. Not a great problem to have with two toddlers!
Nov 04, 2007 | GE WSXH208A Front Load Washer
GE Front Loader
We had our gasket tear as well. Called 6 different online vendors to find this part, WH08X10022, and finally found it at helpfulitem.com. I spoke with Mike who was great in helping me find the part and shipped out very quickly, from Lubbock, TX. to northern Arkansas. Replacement of the part took approximately 30 minutes and now we're back to washing clothes.
I do believe we'll be ordering a spare part just to keep on hand. With four kids, it is quite possible that we'll have it ripped again.
Mar 24, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
97 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
