Question about Sony SRF-M85V AM/FM/Weather/TV Radio
No modes remain on after selected
After power is pressed on the band choice immediately is replaced with a beep sound which brings up the time. With the time displayed none of the other mode or band choices are workable. Pressing the power button 3-5 times will bring on the radio for a second and then the beep and return to the time. thank you drchas
SOURCE: unable to change the DVD 1 Command Mode back to DVD 3 (DEFAULT) SETTING
Had the same problem when I changed the factory settings by mistake. There is no "cancel" button in the remote or the set. What worked for me was to follow the directions on P. 22 of the manual and change the remote settings to DVD 1. This is done by holding the "Enter" button and pressing number 1 on the keypad simultaneously for more than 5 seconds. Then, you go back to the "Settings" screen with the "Settings" button, change the control back to DVD 3, and reverse the setting in the remote by pressing "Enter" and the number 3 this time. Remember to hold them down more than 5 seconds. Good luck!
Posted on Sep 04, 2007
SOURCE: sony remote commander RM-V310
You can get the manual and the codes at Retrevo.com
Posted on Oct 04, 2008
  • 148 Answers
SOURCE: Can't restore factory intallations and settings: Vaio VGN-FE880E
Are you doing DESTRUCTIVE recoveries or are you doing NONDESTRUCTIVE recoveries? Try another hard drive in the machine and recover to that. Nondestructive recoveries replace the operating system without destroying the personal data. Its possible the original problem is propagating over to the recovered systems. Do a destructive recovery. Understand any data not backed up will be destroyed. Possible the original problem was a trojan virus.
Posted on Mar 23, 2009
  • 52 Answers
SOURCE: triangle button on psp
you need to open your psp and clean or replace they d-pad
Posted on Jul 25, 2009
kb8dns
  • 494 Answers
SOURCE: when pressing the power on/off button, the display
These radios have a "**** shell" design and the flexible cable has a tendency to break with many cycles of opening and closing. This can lead to "flakey" operation. A repair kit can be had and installed but for a price. The kit is about 25 dollars and labor would be around 25 to 75 dollars.
Posted on Feb 09, 2010
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
On the bottom ther is two Zz what is it and what dose it do also how do i turn it off fn + f1 is not working
The zz mean that the computer is in sleep mode. Pressing the fn+F1 keys actually induces the sleep mode for your pc. To turn off sleep mode,follow these instructions.
1. Go to the task bar in the lower right corner of your screen.
2. Right -click on the battery icon and select Power Options.
3. This will bring up the Control Panel\Hardware and Sound\Power Options window.
4. On the left hand side of the window, select "Change when the Computer Sleeps"
5. This will bring up the Control Panel\Hardware and Sound\Power Options\Edit Plan Settings window with options for different settings on the battery and plugged in.
6. Click on the arrow for the drop down menu next to Put the Computer to Sleep>Select Never (last option) do this for both plugged in and battery mode if this is your choice.
7. Click on Save Changes.
Apr 26, 2011 | ASUS Computers & Internet
I do not know how to change the mode on the calculator. i want it scientific but i am unable too.
Press MODE to bring up the mode editor. Use down-arrow to get to Exponential Format. Press right-arrow to bring up the choices, then press 2 to select Scientific notation. Press ENTER to save the settings and exit.
Sep 27, 2010 | Texas Instruments TI-89 Calculator
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
11-30-2010 I need the user manual of Amana Mictowave model RS560W . Kindly assist. Thanks. Rgds Alon Felz The real problem: After heating the food (in a certain time selected), a beep sound should be heard...
In order to solve the problem this is what I did (with a help of Mr. Hilik
@ www.microgal.co.il)
1. Unplug the power cable 220Vac from the wall outlet.
2. Make sure or the clock led is "off" and screen is dark
3. Plug again the power cable 220Vac
4. Nothing comes "on" on the led screen
5. press on the digit "zero" (0) and you hear a beep signal
6. Take a glass filled with water press on the digits "1" and then "0" and
then "start"
7. After 10 seconds the beep signal will come on again.
8. Note: this kind a phenomena appears after voltage cut off when there
is a need to lift up again the handle on the voltage breakers . FYI.
Jan 30, 2010 | Microwave Ovens
Clear all the pre-set channels
There's no clear all settings there. You need to manually delete each saved station. Try to unplug the power of the unit for few hours and check if that clears all.
Mar 16, 2009 | Aiwa Audio Players & Recorders
I need to set the date and time for Kansas City , Mo
Select the mode key with the image of the Clock/Globe.
Select the "2nd" mode key in the lower left hand corner to alternate between the QWERTY/TEXT keyboard and the NUMERIC keyboard. Choose the QWERTY/TEXT keyboard.
Select EDIT.
Use the the NEXT button to scroll through city choices until the city name is blank and enter the City and State you wish and press ENTER.
The cursor will then move through the remaining display choices for Date and Time and the keyboard will alternate as needed automatically. Press ENTER after entering the time setting.
Good luck.
Nov 25, 2008 | Sharp Wizard OZ-290
How may I set the vg 2 on my express 795?
Entering Selectable Features Mode
1. With the unit OFF, press and hold the CITY button then press
the PWR/VOL button. The amber X LED will illuminate and a short
“beep” will sound.
2. Immediately after the “beep”, digit #1 will appear and indicate
the status of the sws™ Selectable Feature. To select digit #2 (VG-2
Guard®), press the CITY button again. To select digit #3 (sws™
Voice), press the CITY button a third time and to select digit #4
(Digital Voice prompts for Radar/Laser/VG-2 Guard®) press the
CITY button once again. Use the CITY button to select one of the
four digits.
3. If the selected digit is solid, feature is ON, but may be canceled
by pressing the AUDIO button. Two “beeps” and the flashing digit
will confirm feature is OFF.
4. If the selected digit is flashing, the feature is OFF, but may be
activated by pressing the AUDIO button. A single “beep” and
solid illumination will confirm the feature is ON.
5. Press the PWR/VOL button to retain your new settings for Selectable
Features. Two “beeps” will confirm that you have exited from
Selectable Features Mode and your unit will be ON.
Dec 09, 2007 | Express 795 Radar Detector
Hp 2210
The bulb in your HP PSC remains on for a specified period so that the unit
is immediately ready to respond to your request. When the HP PSC has not
been used within that specified period, it turns the bulb off to preserve
power and displays Power Save On in the front-panel display. (You can exit
this mode by pressing any button on the front panel.)
Your unit is automatically set to enter power-save mode after 12 hours.
Follow these steps if you want the HP PSC to enter this mode earlier.
1 Press Setup.
2 Press 5, then press 6.
This selects Maintenance, and then selects Power Save Mode Time.
3 Press until the desired time appears, then press Enter.
http://h10032.www1.hp.com/ctg/Manual/c01176633.pdf
Nov 10, 2007 | HP PSC 2210 All-In-One InkJet Printer
Sony SRF-M85V AM/FM/Weather/TV Radio Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
