Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Range Kenmore model # is 911.95575790 ser.# 8d183023q Is this oven 230V 3ph. I got it use with no owners manual I need to know how to wire it up? Thanks
  • 8,197 Answers
Yes your oven will work with 3 ph wiring. You need to wire it looking at the back where the wires attach Black, White, Red. Now the red and black can be reversed they both are the hot input that is what makes 240V. also here is an manual if you want to download.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0803193.pdf
Good Luck and Please Rate FixYa!
Posted on Dec 28, 2008
Would like to buy operation manual for mod#970C653520 ser#VF34276106
The 970C653520 electric range was built by Frigidaire with the Kenmore name. Frigidaire has the manual on the support page: http://b2b.frigidaire.com/support/manuals.asp . Just enter the model number in the Search box. The current direct link to the Owner's Guide is ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316902151en.pdf .
I hope this helps.
Jan 29, 2016 | Kenmore Kitchen Ranges
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Change cebora prof 55 plasma cutter from 3ph 4oov to 1ph 230v
Sorry but you can't change a prof 55 3ph to monophase. The 3ph transformer is simetric, but the 1ph prof 55 transformer isn't.
You should change transformer and add a bank of capacitors to compensate the lack of power.
Dec 14, 2013 | Welding Tools
F3 code on Kenmore Oven Model 911 4558810
The F3 error code indicates that the EOC (Electronic Oven Control board) senses a problem with the oven temperature sensor. You could have a defective sensor, a failed EOC or a bad wiring connection between these 2 components.
Normally, a technician is needed to diagnose and repair this type of failure. The technician would unplug the range and access the EOC in the console. He would pull the 15-pin plug from the EOC and measure the resistance between pins 12 and 13 of the plug. This would check the temperature sensor and connecting wiring. The tech should measure about 11000 ohms at room temperature (75 degrees Fahrenheit).
If this reading is good, the EOC would be the failed component and would need to be replaced.
If the resistance reading of the sensor circuit is bad, the reading would be taken directly from the leads on the temperature sensor. If the resistance reading taken directly off the sensor is bad, then the temperature sensor has failed and would need to be replaced. Otherwise, the wire harness is the failed component.
If you have a volt/ohm meter and the technical expertise to safely access and test internal components of your range as described above, you may be able to diagnose and repair the range yourself.
Feb 18, 2013 | Kenmore Ovens
How do I opening a lock door on my Kenmore Oven? Model #790.95599102
we lost our owners manual for our kenmore elit smooth top range and forgot how to use the self clean oven.
May 10, 2010 | Kenmore Microwave Ovens
Ge jsp42 electric range ..Oven heats up very slowly..sometimes can take one hour to heat to 400 degrees..Stove top also slow..
Check the voltage at the outlet. It should be 208v or 240v. check by putting meter probe into the 2/3 slots. NOT the U shaped,or round looking holes.Check one to another. Check tag on range for voltage of range. If you have 208v at the outlet and range is 240v the oven will take forever to heat, it is not getting the power it needs. If the tag says 230v either will work. On the oven tag it will say either 1ph, or 3ph. If it says 3ph you outlet should have the voltage mentioned above between ALL 3 SLOTS! If you get 120v when testing any slot, you have only 1ph of power. Keeping it simple, the ph, (or phase,) between the outlet and oven have to be the same.
Mar 31, 2010 | GE JSP42 Electric Kitchen Range
I want to wire a 3 phase planer up. I have three
install 30 amps 3phase breaker, then wire it up with royal cable 5.5mm x 4wires
Nov 25, 2009 | Powermatic 1791297/Model 209 5HP 3Ph 230V...
Kenmore Coil Top Range - oven portion stopped working abruptly.
If you are getting no codes and If the broiler works OK. Replace the bake element.
Jun 07, 2009 | Kenmore Kitchen Ranges
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
183 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
