If your transmission is making a clicking noise when in gear and is not moving, it could be indicative of a serious problem. Here are a few potential causes to consider:
Transmission fluid: Check the transmission fluid level and condition. Low fluid levels or dirty/deteriorated fluid can cause inadequate lubrication and lead to transmission issues. If the fluid is low, you may have a leak that needs to be addressed.
Clutch or torque converter: If you have a manual transmission, a faulty clutch could prevent power from being transferred effectively from the engine to the transmission. In an automatic transmission, a malfunctioning torque converter can cause similar symptoms. A slipping or worn-out clutch or torque converter may require replacement or repair.
Broken or worn gears: Internal components of the transmission, such as gears or synchros, may be damaged or worn out. This can cause the transmission to make clicking or grinding noises and result in a loss of power transmission.
Hi! I am going to assume the engine runs ok and the shifter moves ok. If its a automatic transmission and it makes noise but wont move in gear the transmission fluid level may be low.Check that first
Well..., then just sit in the driver's seat and make noises like as if you're really driving it (ha,ha)sorry,just needed to put a smile on your face. Anyways,when/IF transmission converter is emptied,it needs to refill fully as it makes mechanisms(valves,so on)work to make the car move;now that is IF it was drained from also there. If you drained the fluid from the transmission pan(drain plug),changed the filter PROPERLY INSTALLED,refilled 2 thirds while engine off then running safely in PARK (parking brake on)fill to recommended amount checking with dipstick ,while in the car with brake pedal on,put in drive-neutral-reverse to make transmission's mechanisms make operation until car starts making a movement, then it should be okay. Are you sure you didn't nock something out of place,like linkage for gear changes??. Does the car make any noises when shifting gears??make a clunk noise??does it try to move??;need to know more details for someone to understand and find problem.
I always try to help on the first reading of a problem, but we need to know if the car is moving or Parked or in gear. Make, Model, Year of car.
If moving, it could be brakes dragging, transmission problems, bearings. If Parked, power steering pump, water pump, Alternator, A/C compressor pulley or unit. Some apply to moving car too!
Sometimes idler pulleys on the belt, dirty belts wiil make spinning noise, but not grind.
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Try unplugging the electrical connection on the transmission to lock it in 3rd. It might get you moving. Although the transmission is going to need rebuilt or replaced.
