Question about Whirlpool Duet GHW9150P Front Load Washer
Duet ok, as a test, I put on the rinse and spin cycle. It does exactly what you said about the door lock/unlock, and it puts the water in, the drum rotates both directions. After about 5mins the pump comes on and runs continuously. With about 6-8 minutes left on the cycle, I get a f02 error. Should the pump run continuously ? and should it not spin at high speed ? Thanks, Scott
  • skmills Dec 28, 2008
    during the rinse cycle there is approx. 3-4 inches of water in the tub when the pump kicks on, it pumps water out but pump never shuts off. It runs until f02 comes up. I took cover off housing while pump was running and the impeller is definitly moving freely. How does the pump know to turn off ? Its almost like it is not getting the signal to shut off.
    President:
  • Whirlpool Master
  • 2,651 Answers
Yes it should run continuosly,(at least untill the water level drops.) a more common instance withthis machine is that the drain line is blocked/restricted, or somethingis ninthe pump housing. it is even possible hat the pump impeller has dislodged from the housing and although it sounds as if its "pumping" its moving no water..usually in htis case your able to open the filter assembly and "pushback on hte impeller(normal impeller will not ,ove back" however if it was dislodged it will have foward play.i would even blow out the drain hose form the pump to the drain standpipe, just in case.
F02 is def a long pump out time and no ther ewill be no high speed spin with water in unit(or if it thinks thers water in unit)
Posted on Dec 28, 2008
  • Ron Coons
    Ron Coons Dec 29, 2008
    just responded on other posting, but the Pressure switch is the indicator of waterlevel, and when its no tsatisified within a given time frame then it trips an error message
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
My washing machine says control locked
Hello there
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
DIAGNOSTIC TEST
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum - Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
Jan 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light will not go off.
Do you have any error codes?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Fron Load washer. Can not unlock door.
There is a manual way to unlock door. I copyed this from the tech sheet.
Manually Unlocking the
Door Lock System
1. Unplug the power cord from
the outlet.
2. Remove the lower kick panel.
3. Reach up along the inside of
the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the
door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about
a ¼” or until a click is heard.
6. The door may be opened.
Also there is a test procedure you can run to check the door lock actuator.
DIAGNOSTIC TEST
touchpad sequence to start the
test.
 Close the door.
this model).
SPIN SPEED touchpad.
times
on this model, press RINSE HOLD
C:00 will light up on the display.
Hope this helps.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet won't run
The trouble could be with the door interlock. When the clothes were jammed in the door it could have caused the door latch to put strain on the interlock.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
91 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
