Question about Maytag Atlantis MAV6000 Top Load Washer
Matyag Atlantis washer didn't drain
I went to switch the laundry from washer to dryer and the washer was still full of water, even though it had completed all cycles. Tried the rinse/spin cycle again and no water drained--I sat and washed. My husband blew in the hose and the water bubbled in the tub, so we don't think the hose is clogged--any suggestions? Thanks!!
  • 4 Answers
It could be a bad timer on the machine which tells it to change cycles i had the same problem and had to call them to come fix it. if this part is bad then it will go through asll cycles and never change cycles does that make sense?
Posted on Dec 28, 2008
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
Our washer smells like mildew or mold whats up?
is it fully draining? old water will start to cause this. wash ur clothes and immediately dry them. dont leave wet clothes in the washer over a days period. hope i helped
Mar 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Did one load of laundry, went to start a new load and no water is coming out. Tried different water temp, different water levels. If this helps the tag on the upper corner of dryer reads as...
Coin or clothing in the pump
Remove the filter and clean out the pump
You first need to put the oulet hose down into a bucket to drain the water off
Feb 13, 2010 | GE Spacemaker Washer and Dryer Electric...
Water won't drain and washer does nothing
pump is stuck or bad located under washer most are not hard to change
Dec 06, 2009 | Dryers
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer is not draining and has slowly filled with water
im not an expert but it might be a leak or somethings backing up or there could be a blockedge in the drain.
Apr 27, 2009 | Kenmore Washing Machines
Maytag atlantis / left on mini load, filled with super load of towels
hi thanks for the question well you could have apiece of clothing caught in pump byputtiing the hose in a bucket on the floor, it will drain the shop vac is cool then you can check the pump theres only 2 hoses and three bolts probably something in pump thanks the appliance doc
Sep 15, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis washer top load --MAV7200AWq
Sounds like you have a loose connection. I would double-check all wiring connections and also the connection from the level control pressure switch.
Feb 16, 2008 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
