Question about Pioneer DEH-6000 CD Changer
Pioneer DEH-P6000UB problem
Bro, forget about the ipod, im gonna order the proper cable UD-IU50 something like that, the problem is the CHECK USB, when i connect my pendrive 4gb datatransfer, the flash of the usb pendrive works, it seens to read, but it does NOTHING, doesnt show nothing, just CHECK USB....
I have vista 64 like u said, i formated in FAT32, and it doesnt work, i did the thing of the ignition
3 Suggested Answers
  • 4 Answers
SOURCE: Stuck installing my Pioneer DEH-1000E
yes try that. I had a Isuzu Bighorn and put a new Sony CD player in, but i used the old casing to fit the new one. so you could try using the old casing, or buy a new one.
Posted on Jan 11, 2009
SOURCE: My pioneer DEH-P6000UB doesnt read USB
I have a pioneer dehp-6000ub but there is not cord for the usb at the back,, what cord if any can I use to use a usb drive on it..
Posted on Jun 01, 2010
Where do i find the port to plug in my usb for my ipod?
behind the unit where the connection wires are, is a black cable that has a usb plug in the end of it. although to play ipods in the unit, pioneer recommend using the CD-iU50 adapter cable. a normal ipod cable may work with certain ipods so i would try that first. I am pretty certain that it just wont charge certain ones. if you bought the unit new it should have had a usb extender cable included in the box.
to access the cable you will need to remove the source unit to plug in your ipod cable.
i hope i have helped you and please dont forget to rate.
cheers
Jan 14, 2011 | Pioneer DEH-P6900UB CD Player
How to connect pendrive usb to JBL ipod dock
Buy a universal USB cord which has many different connecting ends. Easily available in electronic shops.
Connect USB 2.0 to the pendrive and the other end to JBL IPOD dock
Nov 23, 2009 | JBL On Stage Micro Portable Speaker Dock...
Problem of Pendrive
check pendrive with other computers.If it is not working then pendrive having problem.
Otherwise check your smps, some times if you connect more peripherals,
pendrive will not detect because of power problem.
Oct 19, 2009 | Sport & Outdoor - Others
MY PENDRIVE IS NOT GETTING DETECTED
hi im josh in cebu phils. friend if not detected the problem is you usb port or the flash disk. if you tried using your flash disk in other computer and you are sure that it is functional. then go to your usb port.check the connections.check also the confg.from the device manger if the printer port works. then dont forget that windows 98 and older versions of windows dnt automatcaly detect usb.good luck .
Feb 20, 2009 | Intel Motherboard
Dec 28, 2008 | Pioneer DEH-P6000 CD Player
Pioneer DEH-50UB
Hi again,
Appreciate the direct "Ask Me".
Let's try a process of elimination based on:
  • the Pioneer DEH-50UB is working OK other than it displays error communicating with the iPod at certain times (intermittent);
  • the iPod when played alone/by itself does not exhibit any freezing/hanging problems;
  • the iPod to DEH-50UB connector/cable CD-IU50 is in good working order since if it is not, then the iPod would not even be heard on the Pioneer;
  • the Pioneer's wiring are OK otherwise it would not be working.
Which leaves us the possibilities of:
  • corroded/dirty USB port/interface on the Pioneer DEH-50UB;
  • loose USB port on the DEH-50UB;
  • loose or corroded terminals on the CD-IU50;
  • corroded/dirty contacts on the iPod;
  • RF interference from communications equipment such as CB radios, 2mtr Amateur, mobile phones;
  • electrical interference/noise from the vehicle such as horn relay, A/C relay, fan relay, alternator;
  • electronic noise from navigation/GPS mobile equipment;
  • keyless/remote alarm/security system.
Additional actions that could be explored/done:
  • installation of choke/filter capacitor along the red & yellow wiring of the DEH-50UB;
  • additional grounding/groundstrap of the DEH-50UB to the chassis/metal/body of the vehicle.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 12, 2008 | Car Audio & Video
On my pioneer DEH-50UB the error message 'ERROR 19' is constantly appearing, this is addressed in the mannual however it merley advices you to restart the unit. obviously this is not satisfactory when it...
To my knowledge, ERROR 19 on a Pioneer DEH series indicates failure on the USB connection. This is usually reserve for an iPod direct connection. If you are using such a device, pls:
  • check the Pioneer CD-IU50 USB Interface Cable;
  • reset the iPod;
  • disconnect the iPod and try again;
  • reset the Pioneer by removing the yellow and red connections. Pls note that some versions would require a security code when reconnected. Pls have this ready if and when your particular unit has a security/anti-theft feature;
  • reference page 32 of the manual.
Nov 09, 2008 | Pioneer Car Audio & Video
My 4gb kingston pendrive is not recognize by any computer
Hello
For Solving your problem do the following
1. Check that the USB is connected properly to the mother board
2. USB 2.0 Drivers are loaded
3. See that the Pendrive is properly connected
Let me know that your problem is solved and rate me as Fixya!
Sep 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My ipod will not charge on the docking station
my ipod wont charge. it shows the charging icon, but when i take it off the charger it dies like it didnt charge at all
May 05, 2008 | Audio Players & Recorders
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
