Question about RCA 27V520T 27" TV
Popping noise I've had this tv for about five years, Its an 27" RCA standard screen television. For the first time two nights ago it started making this popping noise in the back and along with it the screen sometimes will get a white line going across it but only when it makes the noise. I left it on still after hearing this and a couple hours later it became loud like someone was slapping their hands together. The next day i turned it on and it was back to the lower popping noise. It makes the noise for about 5 minutes after i unplug it even. We took the back of the tv off and vacuumed out as much of the dust that we could but it didn't stop the noise. Any idea what to do?
  • 1 more comment
  • deer hunter Nov 02, 2007
    JVC 32" standard TV makes "Thumping or Popping" pattern but no Leds lit or any other sounds. Can't turn off with remote or on TV - must unplug to stop sound. Help!!!!!!!!!!
    Elmer
  • rickrad Dec 26, 2007
    popping noise on tv
  • Anonymous Oct 12, 2008
    We have a 32" F32649 doing the same thing, I assume the same solution? Is it easy to get the back off without breaking it?
    Genius:
  • 1,074 Answers
The anode cap on the back of the tv tube is leaking the high voltage be careful as going into the back of a tv it store very high voltage and could be fatal.the solution to problem get a tube of clear or red silicone discharge the high from the tube,you do this by getting a alligator clip with wire attach clip to a ground wire on the back of the tube attached the other end of the wire to screw driver gently push it under the Anode cap you will hear a popping sound with i little sparks. remove the cap from off the tube get some alcohol wipe the dirt away apply the silicone around the anode and the anode cap place in on back and leave it to dry and cure for about 7 hrs close up back and turn on your tv and all the popping sound is gone.good luck.but if it is the wire for the anode cap that comes from the flyback is the one leaking change the flyback.again good luck.contact me on fixya.com or email me at nicodhem@yahoo.com
Posted on Apr 24, 2007
Menu keeps popping up
Make a hard reset to this set and try.
Oct 05, 2012 | Insignia NS- 27" TV27 TV
I've had this tv for 4 years. About a week ago, the top half of the screen went black..i think the top went out, but im not sure.
Unfortunately it's time for a new set. the lamp ha s gone and the cost to fix will be the same if not more than to buy a new one..good luck
May 04, 2010 | RCA TruFlat 27F520T 27" TV
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
Snowy picture with catv 1 mono on screen
is tv making some.. sound...please tell me..
Oct 20, 2008 | RCA TruFlat 27F520T 27" TV
Rear screen tv
replaced flyback transformer
Sep 17, 2008 | RCA F36650 36" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
TV went out
Hey Jim, The high voltage protection circuit has gone out on the D-board and will need to be replaced. The fuse to the power supply is probably fine. A good repair tech shouldn't charge over $125 for this and it only takes a couple of hours. Let me know if I can be of further assistance.
Jul 17, 2007 | RCA F27242GY 27" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
Televison & Video Logo
1,202 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
