Question about RCA D52W19 52" Rear Projection Television
Audio Recently, there's a "no audio" problem when watching a video or internet tv once my laptop is plugged into the tv set. I have an S-video cable and l/r audio cables plugged in. Never had a problem before, but now no sound from the speakers on the television
  • RCA Master
  • 5,138 Answers
SSB board. Cost for board if they have any 325.00 and up .look on back of TV see if EX-Internal is speaker switch is on internal speaker
Posted on Dec 28, 2008
Connect roku tv to Sony Trinitron
The roku has a cable that you can connect to those 3 plugs. Take the HDMI cable back and give the salesman a piece of your mind. Once your roku is set up you can watch much more than NetFlix.
Jan 23, 2014 | Audio Players & Recorders
I am trying to hook up my cable box so i can watch tv.
At the cable box input, connect the cable (probably labeled "Cable In" or "Signal In").
Depending on the cable box model and available inputs on your TV, connect one of the following (listed in descending order of video quality). Colored phono plugs must match the colors of the plugs on each end.:
  • HDMI (a single rectangular connector at each end - sometimes you need to connect the Audio separately with a two - line cable with red and white phono plugs).
  • YPbBr, AKA Component (Cable with Red, Blue and Green phono plugs, plus a separate Red and White cable set for Audio).
  • S-video (a single round connector and separate Red and White audio cables).
  • Composite (Yellow video cable plus Red and White audio cables, usually sold as a single set).
  • RF out on the cable box connects to ANT or Cable In on the TV with a coax cable.
The various options are always grouped in some manner on both the Cable box and the TV. On the TV, note which input set you use, for example, "Component 1". This is the input you will select to watch whatever channel you select on the cable box.
An unused output on the cable box can go to a video recorder. Some cable boxes may permit setting up two different channels for this purpose; others will only put out the signal from one channel at a time on all outputs.
You may, if you prefer, connect the audio cable from the cable box to a stereo receiver instead of the TV. Usually people connect the audio to the TV, then connect another audio cable from "Audio Out" or "Monitor Out" on the TV to the stereo receiver. That way the sound is from whatever video source is currently selected, and the TV remote control can be used to set the volume. TV sets with this option usually have a setting to turn off the internal speakers so you hear only the external stereo speakers.
Feb 05, 2011 | Televison & Video
I've been trying to use s-video cable to connect
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Right, well, IF your TV has a DB15 Female Plug on it then you CAN, connect it up and it will work, as a second "Monitor". OR If the laptop, has a "Composite Video" a Yellow RCA socket, then you can, connect to the TV's Composite IN. & it will be a second monitor. Otherwise you cannot, the VGA signal is NOT compatible with a TV's input. SOME cards have a connector that plugs into the DB15 and to the TV, but they are "Special". In saying that though you can "Micky Mouse" things together and get an output, but it real poor quality, and disappointing results, there are various posts on the net about doing this if you wish.
Remember DRIVERS, you also need the drivers installed & setup correctly in order for the hardware to work. As a tip, When connecting to a TV, always connect like this......First, plug all cables into TV's correct Video input(s). Connect up the Sound, plug all cables into laptop, turn TV ON. NOW, start the laptop, you should now soon see the an image.
NOTE: Some laptops & other devices, have HDMI out, sometimes, the AUDIO is not passed through, the HDMI cable, & the Audio must be run from Audio/Line OUT on laptop to AV IN on TV.Also some laptops have a socket that a multi-way 4/5/6/7 pins. A connector plugs into this, you then can connect to these connections, as you would normally.
Mar 06, 2010 | Acer Aspire 3690-2196 Notebook
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
Laptop to tv
Your model laptop has S-Video out capabilities. Depending on what model TV you are connecting to, you would then need an S-Video to (whatever input connection your TV supports: S-Video, VGA, RCA, HDMI) cable. Once you have the cable connected, set your TV to the input method for the cable used, and press Fn + F4 on your laptop Keyboard to project the image over. May need tp press more than once depending if you wish to only display on one screen or both. S-Video is only a video out cable, so you will alos need to run an audio connector cable from your laptop to TV as well, or just use a pair of external laptop speakers for your sound.
Jan 12, 2010 | Computers & Internet
Connecting Laptop to TV
you get yourself a s-video lead..plug one end in pc and other in tv....
on pc f-keys look for the one with a "square" icon on it.(usually f4)
press the fn key and the f4 key together(at once) to switch form pc screen to tv..
make sure youve selected av on tv..you should have an av channel assigned to s-video if not you can assign one in menu settings.
on my tv I have 3 scarts 2 video i/o one front one back and a s-video..video i/o can also be used for audio though there are separate audio outputs.I also have mine linked upto a 10 ft projector screen via infra red so able to watch tv/sky or pc on projector in different room
Feb 03, 2009 | HP Pavilion dv6000z Notebook
Watch laptop movies on TV?
What you would need is a VGA to RCA converter cable. Something like this. Once hooked up, use your Fn key combination to switch the view from the internal monitor on the laptop to the external monitor, now your TV.
Jun 18, 2008 | HP Pavilion dv6000z Notebook
S-Video output
try <CNTL>,<ALT>, and F2 at the same time.
Mar 02, 2008 | Computers & Internet
Vga
you’ll need two outputs on your laptop that are typically found on most: the first is a small round yellow socket usually found on the back of your laptop, which is the S-video socket. The other socket you need is either a line out (unlikely) or headphones socket (more likely). You also need a TV with the correct inputs, which will ultimately decide which cables you need
First, you need two separate cables for video and audio: S-video to S-video...and Stereo 3.5mm plug to 2x RCA plugs..Both cables are two metres long and longer cables are also available..Your TV will require either equivalent S-video and RCA audio inputs or a SCART socket - if it only has the latter, you’ll also need a SCART adapter
Once done, plug them all in and switch your TV on, switching to the A/V channel. If nothing appears, open the Display Properties Control Panel, switch to the Settings tab and click Advanced. Look for a Display tab or something similar where you’re able to switch on the S-video port to enable the laptop’s display to route through the TV. Finally, when watching DVD movies (you’ll need a DVD player to do so), look for the option to run them full screen, so you get the best possible picture from your TV.
Mar 02, 2008 | Acer Aspire 5100 Notebook
LG 42PX4DV - HDMI Audio / PC Audio IN problem
I found the fix. Had the same problem.
I right clicked on the sound speaker icon in the bottom right of Windows 7.
Chose Playback Devices.
Once this window opens, then make sure you are on the Playback tab.
Scroll down until you see the HDMI Device. (Mine was hidden at the bottom of the list.)
Then choose "set as default".
The sound will begin playing on the TV with only the HDMI connected......no need for an extra audio cable.
Sep 26, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
RCA D52W19 52" Rear Projection Television Logo
26 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
