Question about Panasonic KX-TCD580 Cordless Phone (KXTCD580EM)
Display malfunction my phone works ok but after 2 years the display has failed i.e. the screen is completely blank.
  • 332 Answers
SOURCE: display screen has gone blank
You would need to change the screen. Go to a phone repair shop to assist you in changing the screen. It will cost you a little.
Best regards
Posted on Jun 06, 2010
0 characters
1 Points
There is a message "Searching" on the phone, How do I get it back to working.
You might try to de-register the handset and re-register
it to the base. Be sure the handset's battery is well
charged, a weak battery can impede the registration.
( I ) To de-register the errant handset:
1. Press and hold the [END] and [ # ] keys at the same time until the screen displays
"System Reset, Deregister Handset"
2. press [select]
3. scroll to "Base Unavailable"
4. press [select]
5. display says "Not Registered"
( II ) To register the handset to the base:
1. open the base display's [menu]
2. scroll to "Register Accy."
3. press [select]
4. on the handset, press and hold [ # ] until
the handset display says "Registering"
5. In ~30 seconds, handset display will say
"Registration Complete" or
"Registration Failed".
This is described on page 22 of the manual.
A free copy of the User's Manual can be obtained
at .
Jan 15, 2016 | Uniden D16883 Phone
Some of our office phones have display screens that you can no longer read. They are not completely blank but only portions of the dispaly are visable. Is there something we can do to fix the displa
the LCD displays will wear out over time, it would help to know what type of phones you have, some make replacement displays otherwise, there are companies that deal in refurbed phones for cheap with a warranty ie:
Nov 10, 2014 | Phones
My new uniden phone,xdect6145bt+h ,the display screen went blank what should i do?
You phone is completely discharged, it should be charged while charging some kind of icon should appear on screen indicating charging is in progress. If nothing appears then your phone's charging system has gone damaged and to be taken to technician.
May 15, 2014 | Phones
No display panasonic cordless phone
The display on that particular phone may have to be replaced.
Dec 28, 2013 | Phones
I've unplug the phone for 30 min and still no pic nor any display. screen is completely blank
There is no Solution !!!
GE Thomson would like to know the solution.. I have 2 of these that work fine up until we experience a Power Failure.. I have 2 that will not restore after disconecting all connections and reconnecting..
iIf you find me wrong. Then post your successsful solution here.
Feb 15, 2011 | General Electric 27956FE1 Cordless Phone
Display screen has gone blank
Best regards
Jun 06, 2010 | Panasonic GigaRange KX-TG5432 Cordless...
My idect D1i phone keeps asking me to register
Hi , The phones which keep saying Register mean that they have lost the coding for the Base. To re-code them all you do is
press the menu button,
Press down Button 3 times until Setting comes on the screen,
Press the Button Phone/Ok,
The Display should display HANDSET SETTING,
Press the Button Phone/Ok ,
Then Press the Down button about 4 times until Register Comes on the screen,
Enter Base pin ( 0000 )
The Display will show REGISTER IN PROGRESS,
then immediatly press the Handset Locator Button on the Base and hold it in until you hear a tone.
Thats it , the screen should display Register Done.
Mar 06, 2010 | Phones
Display screen is blank
Panosonic KXTG5632 Screen is blank lights up but no numbers or info.phne works fine. Tried removing batt. Any sugestions
Thanks Bill
Jul 15, 2008 | Panasonic KX-TG5632 Phone
Msg-blinks no display
Hi Dan, Yes it is a very nice system, but like any device it is sensitive to electrical storms and power fluctuations. A surge or sag (AC power going up or down), can cause the sensitive digital chips to get damaged, and from my experience if you have tried resetting the unit, and your msg lites continue to flicker and the LCD is blank, it has some serious damage and needs repair or replacement.
Aug 25, 2007 | Siemens Gigaset 2420 Cordless Phone
Panasonic KX-TCD580 Cordless Phone (KXTCD580EM) Logo
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
