Question about Whirlpool Duet GHW9150P Front Load Washer
Seal on fron loader
I have a whirlpool front load washer and the rubber lining has come off can it be put back on
  • 71 Answers
There is a wire clamp and spring that holds the gasket on, loosen the spring and reset the gasket then refit the gasket and spring.
Posted on Dec 28, 2008
Miele W 4840 door seal
the front rubber is moulded to the front hub at the back rubber under the lip is a wire belt that needs to be loosened to release the back rubber making sure both fron and back of the rubber is sealed coretly when putting it back on
May 07, 2012 | Miele W4840 Front Load Washer
LHW0050P Whirlpool washer?
As I understand, when you order the door boot, an instruction paper comes with it. I have done it but each model and make is different. I would research the net also.
Feb 07, 2010 | Whirlpool LHW0050PQ Front Load Washer
I heard you are suppose to clean the washer once a month to prevent mold,is that true?
I have never cleaned my washer as i use bleach in with the whites when i wash. its up to you. they do make a cleaner for that.
Oct 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Bought new rubber seal for whirlpool but no instructions how to fit.has 2 wire rings front and back of seal so how do you fit them around the new seal. do you work from the back of rubber seal first ie...
this is why we are paid to do the tricky stuff. Ok, remove the lid then open the door. look for the front pring loaded wire then remove. Pull front of seal off ridge then bend it back into the tub so it allows you to work easier. you will now see a second large ring holding the other end of the seat to the tub. remove it then pull the faulty seal out. Follow same proceedure putting it back. careful not to tear boot as it is silicon.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loader. did a load of laundry and when i went to get it out the rubber seal is all twisted and the wire spring is off
Is it ripped?If not great all you need is to put the boot back on then reattach the band tighten with i believe eitther a 7 milimeter or 1/4 socket then put the hose slot back on and then the front of the boot following the otther band
Jan 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
190 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
