Problem with Dishwashers
190 people viewed this problem
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
sounds like the jets are cloged you can try a small wire to try and unglog the jets that or you water does not have enoph pressuer hope this helps
Source: dishwasher doesn't clean the top rack whwn we riun it.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Source: DISHES ON TOP RACK NOT GETTING CLEAN.
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Source: whirlpool dishwasher top Spinner and top rack
Recommend you remove the approximately 10 screws to pull the entire filter and manually clean. Remove all debris you find and thoroughly rinse out the filter if you can separate the top from the bottom. If the sump area is greasy, use a de-greasing spray to cut through it. Resemble, checking that there are no blockages in the holes on the spray arms.
Fill a bowl or cup with white vinegar and place it on the lower rack of the empty dishwasher. Do not add detergent. Run the quick cycle. The inside of the dishwasher should now be clean and not greasy. If still greasy, use the de-greasing spray (avaiable at all stores in the cleaning section.)
For 30 days, use only Electrosol or Cascade powder. Do NOT use gel or tablets, ever. Please report back your results. Good Luck!
ianc435 , please ask your question in as a new problem and I will help you out. I understand your problem.
Source: LG dishwasher wont clean top rack dishes
THE TOP ARM IS NOT SPINNING,THE WATER JUST DRAINS OUT AND THE DISHES DO NOT GET CLEAN ON THE TOP RACK. MAYTAG DISHWASHER...
My kenmore dishwasher model 66516034401 does not get the top rack of dishes clean. I put cups in all four corners of top...
Whirlpool quiet partner 1 (du1055xtsq 3) not cleaning top rack of dishes, bottom dishes are coming clean. Not sure how...
Whirlpool Built-in dishwasher Model DUB700XB - will no longer clean dishes, leaving bad limescale residue / dirt on...
I have a whirlpool gold dishwasher model Quiet Partner 3. The top rack is not cleaning the dishes very well. We live in...
