Question about Abit AB9 Pro Motherboard
ABIT AB9 PRO WILL NOT POWER UP
Ab9 pro motherboard starts to power up . beeps a few times and shuts down with the post code 8.A. It keeps restarting and shutting down with the same code. I have replaced the power supply and still the same problem. Any help is appreciated.
  • bryc3 Apr 03, 2009
    I'm having the same problem as you. A few days ago i went to start up my computer and it seemed fine, but a few seconds when it was on it shut off and kept turning itself back on and shutting off again. I checked the cmos display and it says 8A every time. I have taken out everything and still no result. Please help as my only other solution is to pay 130 dollars to replace the motherboard.
  • 177 Answers
Sounds like it's going to die or its gone faulty,
Might need to replace it or take it to a computer store and have them check it out.
Posted on Dec 28, 2008
  • Jackson Henney Dec 28, 2008
    check out this website:
    NO ANSWERS BUT POST CODE DEFINITIONS:
    http://www.pcstats.com/articleview.cfm?a...
    My other solution may have been wrong... Sorry about the other one.
When i try to suspend my pc, my motherboard gets f3 error and then restarts. The model is an old abit ab9 pro. I recently changed the ram and my os. The os runs perfectly.
have to select suspend mode s1 or s3 in BIOS power management to check the support mode, also check with hibernate, also need to free space in hard drive system partition for hibernating
Sep 11, 2016 | Abit AB9 Pro Motherboard
Code 87
Check CPU core voltage.
Carl
May 08, 2014 | Abit AB9 Pro Motherboard
Where to connect the start switch
For the Abit AB9 pro motherboard?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813127004
A) Motherboard installed in the computer case;
Processor to the Top, Ram Memory slots to the Right, white long PCI slots at the bottom;
The Front Panel header on the motherboard, is at the Bottom/Right corner.
[The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header ]
The Front Panel header is a plastic rectangular block, with TWO rows of pins.
20 pins. 10 on the Top row; 10 on the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
TOP row; starting at the LEFT side going towards the RIGHT;
Pins 2, 4, 6, 8, No pin 10, No pin 12, No pin 14, 16, No pin, 20.
{4 pins, blank space where 3 pins would be, 1 pin, blank space, 1 pin }
BOTTOM row; starting at the Left side going towards the Right;
Pins 1, 3, 7, and 9. No pin, 13, 15, 17, and 19.
( Top row: 2,4, 6, 8, X, X, X, 16, X, 20
Bottom; ..1, 3, 5, 7, 9, X, 13, 15, 17, 19
X = No pin, or blank spot )
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, and in use, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
(reset button)
C) Pin 9 is N/C. Not connected. (It was for factory use)
D) Pins 13, 15, 17, and 19, are for a Speaker. The small speaker is used so you can hear BIOS Beep Codes. The computers way of telling you something is wrong, and an area to look into for it.
Pin 13 is for the Positive ( + ) wire
Pin 19 is for the Negative ( - ) wire
E) Pins 2 and 4 are for a Suspend Power On LED light.
Pin 2 is for the Positive ( + ) wire.
Ignore.
F) Pins 6 and 8 are for the Power On switch.
G) Pins 16 and 18 are for the Power On LED light.
Pin 16 is for the Positive ( + ) wire.
If the Power On LED light is dim when the computer is on, switch the wires around.
Motherboard manual. It is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click it may take up to 30 seconds, before the first page comes up.
Page 15.
http://static.tigerdirect.com/pdf/Abit_ab9_series_Manual.pdf
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 21, 2012 | Abit AB9 Pro Motherboard
Abit ab9 pro motherboard diagram
Abit Support > Abit AB9 Pro motherboard > Motherboard manual download page,
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AB9+Pro&pSOCKET_TYPE=LGA775
On this page left-click on the country nearest you
(Asis, Europe, US)
After you click a small window will come up -
Opening ab9_series.zip
Make sure there is a green dot in the circle to the left of Save File.
If not, left-click on the circle.
Now go below, and click on OK.
A small download window will appear on the left.
While it is downloading look at the heading.
It will show the percentage rate of downloading, and state where the file is going.
Example: 50% downloading - Downloads
I just downloaded the file. It is going to a sub-folder within the My Documents folder called Documents.
(WinXP: Start > My Documents > Downloads)
For me I will go to the My Documents folder, then double-click on Documents.
The file may go to the same place for you, or to your desktop screen.
This is a Zip file. You need a program to Un-zip the file, if you do not have one.
If you do not have a program I suggest you download 7-Zip for free.
(Zip files are used to send large files easily)
When you see the file name, Double-click right on it.
Click on Next, Next, and Finish.
You will now see a small window with the file name next to an Adobe PDF icon.
Double-click on it.
If you cannot download this file, let me know in a Comment as to what you wish to know about the motherboard, and I will post back in an additional comment.
Regards,
joecoolvette.
[ Thought I would include this also,
http://www.viperlair.com/reviews/cpu_mobo/abit/9xx/ab9pro/ ]
Oct 11, 2010 | Computers & Internet
I re installed windows XP and now my ethernet
You can find drivers for your motherboard at the following location:
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AB9+Pro&pSOCKET_TYPE=LGA775
Scroll down and look for: Realtek Gigabit Lan Driver
Aug 02, 2010 | Abit AB9 Pro Motherboard
When i power on a led is blinking next to the mb power suply and apears two errors 82 and 98 i have tried diferrent power suply, ram, vga card
remove the bios battery for 20- 25 mins.small flat round battery on the motherboard then put it back in. start up computer
Aug 05, 2009 | Abit AB9 Pro Motherboard
Manual and Bios for Abit AB9 Pro Motherboard
Hello seany187,
What I'm doing since your system doesn't want to download from Abit, is creating a zip file with all the drives, manuals, utilities and bios updates for both XP, XP64, Vista, and Vista 64, since I don't what OS your on, and you will be able to download them from this private site HERE. And because the files are so large, I split them into, I'll post the second one as in a comment as soon as it's completely up on the site.. You shouldn't have any problems with these downloads, unless you have your IE settings to high.
Good Luck & don't forget to leave a rating based on my Solution.
Thanks Mark
Stay tuned for the second file!
Apr 06, 2009 | Abit AB9 Pro Motherboard
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here, http://forums.hexus.net/abit-care-hexus/104674-abit-ab9-pro-code-25-error.html
Dec 21, 2008 | Abit A17 Guru Motherboard
Badly flashed bios
i can fix that if only you are in my country(Philippines)
Sep 22, 2007 | Abit AB9 Pro Motherboard
Abit AB9 Pro Motherboard Logo
574 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
