Question about Kodak EASYSHARE 5100 All-In-One Printer
5100 blinks check color ink, but it won't scan or copy either. We did lose power for awhile and I'm thinking it needs to be reset. Possible? Any suggestions?
  • Anonymous Feb 03, 2009
    we should be able to use the scanner no matter what state the ink heads are ...
    Sergeant:
    Novelist:
  • 326 Answers
U can reset the printerby turning it off n removing the power cord for a while and then reinsert it and onthe printer.but if color cartidge is actully faulty thenu will hve to replace the cartridge to make it work.
Posted on Dec 28, 2008
Printer won't scan because it's out of ink
Unfortunately, all-in-one printers are printers/copiers. The scan to a computer function is a secondary function and the unit has interlocks to keep it from being damaged when the ink is out. There is a way to print with only one ink cartridge in place but this only allows print jobs from the computer. The copy and scan functions are locked. For details, see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01673672&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3742086#N2374 . See the section on Ink Level Indicator (!) and the bottom notch of the indicator blink fast and the Workaround: Print in ink-backup mode
You need a stand-alone scanner if you routinely want to scan to your computer without a printer ink level OK status report.
I wish that I had better news for you.
May 23, 2012 | HP F4480 All-In-One Printer
Service error 5100
hiTurn on your printer
After that press: Menu - Scan - Copy - Scan.
It will enter in Service Mode.
Here I don't know exactly the procedure but may be something like that for mpc190/200 that follow:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-Scan-Copy-Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
I hope this helps youRegards
Mar 07, 2012 | Canon PIXMA MP130 All-In-One InkJet...
Service error 5100
Hi,Turn on your printer
Hope this will help youRegards
Mar 07, 2012 | Office Equipment & Supplies
Ink level will not reset when cartridge is replaced
If you take the cartridge to walgreens, etc... they can clear the chip. There is none for home use
give them a call !
May 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Check color ink light blinking
You probably need to clean the jets. On your computer you should have an icon for your printer type? Lexmark, Epson, etc? Well doubleclick it and it should have options for troubleshooting or maintenance. Go there and follow the instructions for cleaning and aligning the printer. Until you do that most printers won't reset to show the real levels anyway. Hope this helps. Let me know.
Mar 29, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How to reset ink cartridge for mp 160
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
Sep 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Kodak easy chare 5100 scanner
kodak is the worse i have the same problems just wait till you need new ink
Aug 25, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Error code 5100
Here's what worked for me in solving this error code 5100 problem. Not only was I unable to print anything because I kept getting that code, but there was a thunking sound when the carriage stopped moving, and every time I turned the machine on it was feeding through one sheet of blank paper. I was about to go out and buy a new printer of a different brand because the Canon was unusable.
Then, fooling around with the machine's menu and settings buttons, I came across an option, I think it was in the Maintenance menu, to Restore Factory Settings. I chose that option and it asked me again if I wanted to restore the original factory settings, Yes or No. I said Yes, and immediately the printer started behaving itself. No more 5100, no more funny noises, no more blanks sheets of paper. It is back to its old self again.
That still doesn't solve the problem of spending a fortune to buy ink cartridges, but I just hooked up my old Panasonic 24-pin dot matrix printer to the printer port of my CPU (a ribbon lasts me a year and costs less than $15), and the Canon to another port, so now I can print the day-to-day stuff on the cheap dot matrix and use the Canon for the important stuff.
I don't know if restoring the factory settings will work for you, but it was the solution in my case. Hope it helps you out.
May 04, 2008 | Office Equipment & Supplies
Prnter kodak easyshare 5100
just to check, is what specific lights is blinking is it the check color or just check black inks??
-to make sure w/ this one is it blinking too fast or slow and what is the color?? check if the on and off is also blinking
-check black ink and check color cartridges blinking fast means no printhead installed
-check black ink and check color cartridges blinking slow, no cartridges installed
-check black ink and check color cartridges blinking w/ on and off ready to calibrate
(in ready to calibrate if doing nothing, just press cancel and
-press photo and cancel on printer, if not doing anything
-remove printhead( the one that holds the cartridges) turn printer on and off, put printhead back to printer w/ cartridges, and check the lights that is blinking
-press photo and cancel again
-if not doing anything, contact manufacturer
-goodluck
Mar 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
The Kodak Easyshare is a piece of ----.
We had the same problem then I took the ink back out and if you look at the diagram on the printer it shows after you put the ink back in you have to push firmly on the gray tab under the new ink cartridge and eveything went back to normal hope it works for ya
Dec 11, 2007 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
59 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
