Question about Sharp AQUOS 52" Flat-Panel LCD HDTV
New Sharp Aquos LCD 46 TV
Can't get any of the channels to work. Not hooked upto HDTV. Hooked upto satellite. TV tries to recognize channels but doesn't. This is the initial set up of the TV.
    Problem Solver:
  • 15 Answers
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Posted on Mar 14, 2009
Why is my Sharp 32 inch 32sb28ut freezing up on any channel we put it on.
If you have a HD antenna hooked up to it and it has a low signal it will freeze up allot
Mar 03, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I cant get my tv to get the regular cable channels. i just hooked it up to a new connection, it has no digital box, it runs straight through the cable. ive done the channel search and i dont know what else...
If your TV has a menu button, go into the menu and try setting the input of the TV to the jack that you connected your cable to. Sometimes the TV will not check all the inputs and just does the default one when you do the auto-tune search function to find the active channels. Also, check to see that your wall receptacle is actually hooked into your active cable TV line. You should have a splitter somewhere in the same line that your other TV is using. If not, that jack that you are hooking up your new TV to is probably not active.
Jan 01, 2018 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Aquos Screen Image Too Big.
I had the same problem, but it looked like my son pressed the view mode button on the remote. I set it back to Dot by Dot and it looks perfect again. Try it out.
Sep 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Installation question
For any electronic component, use the best connection that is available.
Good = standard composite/rca/yellow, red, white
Better = component cables (red, green, blue, white, red
Best = HDMI (find them cheap at www.monoprice.com)
Mar 25, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos LC 37D43U
If you have satellite, I am assuming you at least have a converter box hooked up. If so, make sure the converter box volume is set at its max. There may even be a volume setting in the converter menu that forces the volume output of the box to always be at full so that you don't get variations in audio when changing channels. Warning...before attempting this, please turn down the volume on your tv to at least the middle setting so you don't blow your tv speakers if this works.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp AQUOS 52" Flat-Panel LCD HDTV Logo
403 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
