Question about HP PSC Photosmart 2355 All-in-One Printer
Printer wont print
It will copy and i just this morning printed out a picture but now i cant get it to print this is just the last couple days problem Help!!
SOURCE: My printed and copied pictures have horozontal lines
I work on printers daily and if I can make suggestion. The printhead (ink cartridges) are cleaned or wiped off before printing. Normally on the left of most printer at a cleaning station. You dont say what model you do have. but the rubber wipers accumalate the ink that the clean off the printhead and when they get too dirty thery generally dont clean the printhead as well as they should so they smear ink across the printouts. A wet paper towel to clean the rubber wipers, let it dry a bit then turn it back on and try it again. Good Luck!
Posted on Mar 15, 2007
SOURCE: Print last document on start-up on new day
Check the print jobs. If it still has print in the que it will keep printing.
Posted on Apr 04, 2007
  • 31 Answers
SOURCE: HP LaserJet 2420dn prints twice
You may have checked this already, but make sure your printer driver is not set up to print two copies per print job if it is then that's the easiest place to change settings. Or you can print out your printer's menu by doing the following: To print a menu map 1. Press (SELECT button) to open the menus. 2. Use (UP button) or (DOWN button) to scroll to INFORMATION, and then press (SELECT button). 3. Use (UP button) or (DOWN button) to scroll to PRINT MENU MAP, and then press (SELECT button) Look for anything that says "copies" and usually that will let you know what is set on the printer. To change a control-panel setting 1. Press MENU to open the menus. 2. Use (UP button) or (DOWN button) to scroll to the menu that you want, and then press (SELECT button). 3. Some menus might have several submenus. Use (UP button) or (DOWN button) to scroll to the submenu item that you want, and then press (SELECT button). 4. Use (UP button) or (DOWN button) to scroll to the setting, and then press (SELECT button). Some settings change rapidly if (UP button) or (DOWN button) is held down. An asterisk (*) appears next to the selection on the display, indicating that it is now the default. 5. Press MENU to exit the menu Good Luck.
Posted on Aug 24, 2007
SOURCE: Can not delete last file in print queue.
hello sir
my printer is not prople printing . me print sahi se kaamnhi kar raha hai. mere printer me problem yah hai kime jobhi printing kerta hu us me wo sahi printing nhikerta hai or beech beech me se akshar type nhi karta hai. jab ki amne new cartage bhil lga li hai but koi bhi fayda nhi hua hai . wo beech me se sahi printing nhikarta hai. plz koi solution btaye
Posted on Feb 13, 2008
SOURCE: Printer will copy and scan but will not print anything from internet
copi driver instal to my computer
Posted on Oct 02, 2008
  • 822 Answers
SOURCE: HP D4160 Everything OK, except blinking orange arrow; cant print!
reset printer.
Posted on Jun 01, 2009
0 characters
1 Points
Will not print
my printer will NOT copy but will print from the computer ... > ... > Scanning / Faxing
Oct 4, 2010 - 10 posts
HP Support Forum Home; >; Printers, Copiers, Scanners and Fax; >; Scanning / ... my printer will NOT copy but will print from the computer).
Copier Won't Print Top 3 Reasons Why cant clear print job
Sep 4, 2014 - Service calls are costly, not to mention when the copier won't print it disrupts ... The printer (for many reasons) can have trouble interpreting the ...
All of a sudden my copier wont print. Paper and ink okay. > Printers
Question - All of a sudden my copier wont print. Paper and ink okay. - OY. Find the answer to this and other Printers questions on JustAnswer.
Printer and Photocopier Troubleshooting and Repair ...
Jan 28, 2016 | Printers & Copiers
Canon pixma mp610 cant delete the printing queue or print
This is not the fault of the printer but windows. Open the Control Panel, select Devices & Printers, find your printer, click on it, select Delete Print Queue. Problem is fixed.
Jan 07, 2013 | Canon PIXMA MP610 InkJet Printer
I have anX2480 printer purchased with a computer from Curry's in July 2007. Over the last couple of days after printing 4 copies the printer ceased to work and the statement "Printer Status Window...
I would replace the printer Newer ones use less ink less energy and the drivers are up to date. A new printer can be purchased for the price of the ink cartriges.
Jan 23, 2011 | Lexmark Printers & Copiers
Cant print text but prints headers, footers and pictures
try to make a copy ...if success
try to disconnect the power cable from the back of the printer and reconnect it after 20 seconds
try to print from the notepad ...............if success great
or else
uninstall the printer from the computer and reinstall the printer as a fresh
it should work and it has worked in most of the issues ................. thank you
Oct 20, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer prints more copies than indicated. Driver reinstalled multiple times. Problem is not that is follows previous print number.
The printer has performed correctly for two days now - first consecutive days since purchase 6 months ago. I did not do or change anything - have no idea why it is printing the correct number of copies now. I am not confident that this will be longlasting, however.
Jun 01, 2009 | HP Photosmart C6380 All-In-One InkJet...
I replaced all the ink and my brother mfc 240 still wont print black, or copy black, or test print black
i replaced all the ink and my brother mfc 260 still wont print black, or copy black, or test print black
Mar 24, 2009 | Brother Multi-Function Center MFC-240C...
need to install printer to my lap
Sep 28, 2008 | Lexmark X1240 All-In-One InkJet Printer
Not printing
Contact Kodak! I had similar problem after a paper jam. I phoned three days ago and this morning, a new printhead arrived along with two new cartridges. Have installed the printhead and printer is printing beautifully! Thank you Kodak! Great customer service!
Aug 25, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Problem with Printing BLACK AND WHITE picture on Epson Stylus C88
i think theres problem on your printer head ..try to decloge printer using head cleanig on printer properties.. or other option is to removed printer head steam nozzle on hot hot water to easy removed clog make it sure its dry before you install and the last option is to replaced printer head... tnx good day.
Dec 14, 2007 | Epson Stylus C88 InkJet Photo Printer
HP PSC Photosmart 2355 All-in-One Printer Logo
16 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
