Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore 596.72289200 Freezer fine, but refrigerator not coolin
The bottom freezer drawer is operating fine, but the refrigerator is running but not cooling. Not sure what to do
  • scottkenney Dec 28, 2008
    I have a snowy frost across the back 1/3 of the freezer panel. I used a hair dryer to defrost it and it got the air flowing back into the refrigerator. What is the best way to go about determining what is the problem that needs to be fixed
    1. defrost heater?
    2. thermostat?
    3. timer/control board?
    Are these things that can be checked on and fixed by a novice handyman as myself?
    Thanks for you help!
  • 318 Answers
You must not be getting any air flow into the refr section. make sure the fan is running and if so then you may have a defrost problem. look at the freezer section rear panel, if it has heavy frost on it then it is not defrosting properly. there are a few problems that could cause a defrost issue. defrost heater, thermostat, or timer/control board. most likely the defrost thermostat.
if it is frosted over, then shut off the unit and get ready to catch the extra water that will run onto the floor, after a full day turn it back on and if it cools, you will know that you are not defrosting. it will work ok until it frosts over again, in about 2 weeks. then you will need to find out which part is bad causing the no defrost.
Posted on Dec 28, 2008
  • Tom Zwiebel
    Tom Zwiebel Dec 28, 2008
    well i would say your not as novice as you think. you have all 3 items that control the defrost cycle.
    the most common one to fail is the thermostat, then 2nd the control, whether a timer on board, and last the heater.
    if you can get the rear panel off the freezer section then you can get to the thermostat. i would start with replacing that. it has 2 wires on it and is about a 1" round device. try that first and if after another week or 2 you still get that frost build up, then come back with a model # and i might be able to get you some more info.
    p.s. the defrost thermostat should cost about 20-30 bucks.
Took freezer drawer out and cant get it back in
Lift the front of the drawer while sitting it on the runners push it back and let it run naturally into the freezer
Apr 22, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Water pooling below the crisper drawers at bottom of the fridge. Kenmore model #363.79262991
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Kenmore Top Freezer Refrigerator
Bottom drawer of the refrigerator freezes the fruit.
I think the thermostat is faulty. Thus it makes the freezer extra cold. Try replacing it. Regards, Nandini.
Sep 07, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Freezer drawer closes on right but gaps on left side for Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator, frosting contents. No contents blocking. Can manually hold left side closed, but wont...
I had this problem with my Kenmore bottom freezer drawer also. I found that the problem was I had too much weight at the very front of the drawer. Try reorganizing and moving items, especially heavier items away from the very front. Worked for me.
Jul 10, 2009 | Kenmore 73503 Stainless Steel Bottom...
Kenmroe64802 refrigerator not cooling
You are probably storing items too close to the top shelf of the freezer, stopping circulation.
May 01, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer Drawer won't open on Kenmore 22" Bottom Freezer Refrigerator
Try raising the door. It may be off the roller tracks inside. If you get it to open you'll find the problem. These tracks are like kitchen drawer tracks.
Jun 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
262 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
