Question about Seagate Medalist 8420 (ST38420A) Hard Drive
Configuration 1762 162
I installed an opld 8.6 gb hard drive into my computer. unfortuanatley when i start power it wont read the hard drive. it gives me the message
configuration 1762 has changed
configuration 162 has changed.
afterwords it sends me to the configuration/setup menu, but only allows me to see that it didnt reasd the hard drives plugged into it. is it the hard drive or my motherboard having problems
askanything
  • 151 Answers
SOURCE: Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Posted on Sep 25, 2007
iqbal_del
  • 655 Answers
SOURCE: SEAGATE HARD DISK DRIVE PROBLEM...
grt seagate nice brand...
whenever yor OS is currepted this type of messages raised. its not only due to bad hard drive. I think your hard disk is ok. If you want to make a check you can run scan disk to see if you have any bad-secter on your HDD, if you have then its HDD problem, otherwise its ok.
Thanks
Iqbal
Posted on Apr 01, 2008
mdsaeed67
  • 849 Answers
SOURCE: Sata drive not detected
just no other solution except upgrading BIOS properly
Posted on Oct 27, 2008
SOURCE: help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
Posted on Nov 03, 2008
Chinthakaj
  • 416 Answers
SOURCE: PC does not detect Seagate 500GB external hard drive
Try using the device on another PC & see if it works. if it does then you have a issue with your PC. whast the OS you are using? also try another USB port.
Posted on May 06, 2010
How do I get my acer aspire xc600 to stop giving me "error reading drive disk or drive disk failed" messages?
You are probably not doing anything wrong it sounds as if you have a motherboard problem a quick test is to put the old hard drive into another computer if it works in the good computer it more than likely the motherboard in your computer that is failling
Aug 11, 2014 | Acer Aspire XC600 Desktop Computer - Intel...
WHY WONT MY STOREJET 320 GB DRIVER INSTALL. SAYS ACCESS IS DENIED ?
first check whether the device is working on another computer. if it is then there are driver issues on the computer you got this message from. if not then your casing interface is not working right. you can get the data off the hard drive by removing the casing and plugging the drive to a desktop computer.
May 09, 2014 | Transcend TS320GSJ25M2 - Storejet 25M2 320...
My external hard drive got a virus had to reformat now computer wont recognize it
I am taking for granted that you are using Windows, not sure which version ( XP , 7, 8 , 8.1 )
and if I am correct, but your computer does not recognize the drive, make sure the usb port is one that will give power to the external drive. You should use USB2 or if available USB3. Those are powered.
Click the Search feature for the particular version of Windows you are running and search for "Disk Management"
Look for the partition of the external drive you are using. It will be given a letter other than C: drive. May be D: E: F: etc etc etc. Sometimes your optic drive is the D: drive, you may need to purchase a program like Everest Ultimate to locate ALL your items on the MOBO.
If your able to find the External in Disk Management, you should be able to format it, rename it, change its functions, etc etc.
Good Luck
Oct 21, 2013 | Toshiba 120GB USB 2.0 Portable External...
I have had an Evesham PC desktop computer since 2002. I use Windows XP. Is there any possibility of downloading Windows 8? Annie
You might need to upgrade a few hardware items first also you might upgrade to vista then windows 8
Creating a new partition on your hard drive gives your future version of Windows 8 a place to live on your drive.
Knowing exactly how much space the OS requires helps you determine how large to make your partition.
Size requirements don't tell the entire story on their own, though.
Other factors like drive type and additional storage help ensure you get the best Windows 8 experience where your hard drive is concerned.
Size Requirements
Both Windows 7 and Windows 8 have the same system requirement regarding hard drive space, so if your hard drive can handle Windows 7, Windows 8 shouldn't be a problem.
For 32-bit versions of the operating system, you'll need at least 16 GB of available disk space. The 64-bit version requires 20 GB.
Your partition will have to be at least one of these sizes, depending on your OS version.
The PC Advisor website warns that these are literally the bare minimum requirements, and using these figures leaves you hardly any space to save files and install apps or programs.
Size Recommendations
You'll get more out of Windows 8 if the operating system has enough free space for you to install your favorite programs and apps.
PC World calls this extra space "breathing room," suggesting you give your Windows 8 partition at least 30 to 40 GB.
If you're dual-booting with another operating system or you're accustomed to keeping excess data on a separate partition, 30 to 40 gigabytes should be fine.
If you'd rather have all your songs, videos and PC games on the same partition as the operating system, consider giving it substantially more space.
Solid State Drive
Windows 8 works on traditional hard drives with spinning disks, but it's optimized to run on a solid state drive.
If you've got an SSD, consider putting your Windows 8 partition on that drive.
While any operating system benefits from the speed increase an SSD brings, ARS Technica specifically recommends this drive type for Windows 8, saying the operating system's "tablet-esque feel and search-heavy usage model will be much better served by solid-state storage."
Other Requirements
Hard drive space is a crucial system requirement, but others are just as important.
Ensuring your computer meets the other requirements before partitioning your drive for Windows 8 saves trouble in case your computer can't handle the OS.
You'll need at least a 1 GHz processor that support PAE, SSE2 and NX.
Your computer has to have at least 1 GB of RAM for 32-bit Windows 8, or 2 GB for 64-bit.
Your graphics card must be at least a DirectX 9-capable card with a WDDM driver. Also, while you're formatting your drive, format the Windows 8 partition in the NTFS format.
Storage Spaces
Storage Spaces is a useful Windows 8 feature when you're working with multiple drives and partitions.
The tool enables you to group drives into one larger storage space so you don't have to constantly switch partitions and explore different drives.
For example, if you create a storage space between two 32 GB flash drives, you'd be able to access it as if it were one larger 64 GB drive.
http://windows.microsoft.com/en-us/windows-8/system-requirements
Microsoft windows 8 system requirements
http://www.pcadvisor.co.uk/features/windows/3358892/windows-8-system-requirements/
PC World windows 8 system requirements
http://www.pcworld.com/article/2012847/how-to-master-storage-spaces-in-windows-8.html
PC World how to master storage space windows 8
http://windows.microsoft.com/en-US/windows/download-shop
Sep 11, 2013 | Evesham Computers & Internet
I switched my IDE hard drive into another computer that is a little more up to date. computer boots, passes post, shows these options " safe mode, safe mode with networking and command prompt. start...
As the Windows installation is installed on the first computer hardware configuration and now it is moved to another computer hardware configuration, ie another computer. It will not work as Microsoft prohibits moving/changing hardware configurations to the extent of another computer system.
In your case you will have to return the hard drive to your original computer and then backup your files. Then this hard drive needs to be formatted, all data will be lost. Then the hard drive can be install in the better computer and a fresh installation may be performed. However you will need to read the terms and conditions of your Windows License Agreement to see if this is indeed possible.
With regards to the DVD drive, it needs to be connected on the IDE2 port, right at the end of the IDE bus/ribbon. There are 3 positions a longer length and 2 shorter lengths.
Long side plugs into the mainboard, the middle one is left open and the shorter end one is plugged into your DVD Drive.
Ensure that the jumper located between the power and IDE port of the DVD drive is set to the Master Position. The details can be found on the label on top of the DVD drive.
Thumbs up!
Thanking you
damnor01
Mar 15, 2011 | Microsoft Windows XP Home Edition
Making click noise wont read
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered sucksion vacuum cleaner or a fine air blower from a air compressor making sure there is no moisture in the air lines then give the hard drive a firm tap on the side to free it up
hope this helps good luck
Sep 04, 2010 | Iomega (33215) 250 GB Hard Drive
My power source on one of my 500GB external hard drives seems to have malfunctioned. I am told that I can switch the faulty hard drive to my other and recover my data. I opened it up but have no idea what...
I assume you have a RAID 1 or "safe" configuration, i.e., two 500 GB hard disks which give you a total of 500 GB "safe" data. If you have a RAID 0 configuration (two 500 GB disks for a total of 1000 GB "fast" data), half of your data is now inaccessible and you'll need to ask a data recovery firm; I'd advise against trying to do it yourself.
With RAID 1 configurations, it's all much, much easier and safer.
The following does not work with "ALL" RAID 1 units; but it does work with most of them!
You need an external USB enclosure (not RAID), single disk, compatible with your existing disk. There are also "open air" connectors such as one from Kraun which accommodates both SATA and EIDE drives, and comes with an external power source, and which I warmly recommend (can be a lifesaver).
Connect the hard disk to the device's USB cable, connect the USB to your PC, and finally connect the power source. On some computers you need to first connect the power source to the drive, and connect the computer to the contraption last.
At this point there are two possibilities. One (rare): the RAID1 enclosure employed a partitioning/filesystem scheme which your PC does not support (e.g., HFS or something). You may be able to "see" the hard disk from a computer which "speaks" that filesystem: a Mac, or maybe a Linux computer.
Two (most common): the manufacturer used the simpler and cheaper and faster way, which is to split the EIDE signal and add very little circuitry to countersplit the drive controls. So the disk content is directly compatible with your PC. Also, the partitioning and format are the PC's native ones to save time and resources on data format conversion. You will hear the tingling sound of a hard disk being recognized, and all your data will be there.
Read EXTRA CAREFULLY your RAID1 manual for how to replace a broken disk: you want the GOOD disk to be copied onto the new, empty one, and not vice versa! If in doubt, buy two new disks and replace BOTH of them in the RAID1 enclosure. Then copy the data from the old, surviving disk onto the two brand-new, maybe bigger and faster ones.
Hope this helps, let me know how it goes.
Mar 18, 2010 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
Laptop not booting up after XP install
Can you press f10 to get to the HP recovery screens?
May 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Plz Help
Is ur hard drive is SATA and greater than 200 GB ??If yes then u may get this error...
Dec 03, 2008 | AcerPower 1000 (AP1000EA380M) PC Desktop
Plextor Problem
I had problems with that drive as well ,, i found it utterly stupid , in order for me to get it to work i had to format my computer and reinstall everything. apparently the signiture from your old drive is still in there or nero 8 has a bug.. and cant use the new drive sig. and way i used nero 8 as well and wound up formatting ( nero 7 ) worked thought but the system becomes unstable and starts freezing
I recommend you format if you want to use that drive
Dec 25, 2007 | Plextor PX-800A DVD Super Multi Drive...
Seagate Medalist 8420 (ST38420A) Hard Drive Logo
118 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
