Question about Hotpoint 21.7 cu. ft. Side-by-Side No-Frost Refrigerator with Dispenser CSX22GRBWW
Refrigerator warm, frost in freezer
The fan in the freezer is working and the fan near the compressor is also working. Fridge is still cool and freezer is cool despite the frost. What could be the problem?
  • 1 more comment
  • Anonymous Mar 16, 2014
    freezer cools a little and has some frost on it, but the refrigerater is not cooling at all.
  • Anonymous Mar 20, 2014
    freezer is working but the refrigerator is not cooling. the cooling fan is working on an intermitant basis, not sufficient to cool the refrigerator
  • Anonymous Mar 21, 2014
    Freezer is cold, refrigerator is warm to cool
    President:
  • 1,462 Answers
Take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Posted on Apr 24, 2007
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Oct 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
Where do I start to troubleshoot when it does not cool, the fan is running?
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
Sep 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
Frig won't cool RM2652
You'll need to get in touch with the store you bought it from but Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Jun 26, 2010 | Dometic RM2652 Refrigerator
REFRIGERATOR NOT GETTING COLD
Is the compressor motor running.If no check starter/overload relay. If the relay is ok there is a compressor problem or low freon it it don't start
May 30, 2010 | Refrigerators
The refrigerator is not cooling either the freezer or the fridge I dont know what to do it stays hot.
Is the compressor motor running.If no check starter/overload relay. Place a probe on each terminal. The multitester should display a reading of zero ohms. If the overload protector does not pass this test, it should be replaced.
How to check stuff>
Feb 09, 2010 | Frigidaire FRS23H7CS Side by Side...
It stopped freezing and the temperature keeps rising
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
How to check stuff>
Dec 13, 2009 | GE Profile Arctica Stainless Steel Top...
Will not keep cool any more freezer or fefrigerator
How to check stuff>
Sep 09, 2009 | Refrigerators
The freezer fan works, the compressor hums but the fridge does not get cold, nor does the freezer. Even with the settings on max.
How to check stuff>
Aug 27, 2009 | Refrigerators
I have a Model #GD5RHAXNB0 and the compressor keeps cycling. It is not cooling.
How to check stuff>
Aug 22, 2009 | Refrigerators
Refrigerators Logo
362 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
